Reverse Ryobi tool kit unboxing?
    I bought a Ryobi tool kit when we got stateside and I used a couple of the tools, but we're going to head out again. I can't for the life of me figure out how to get these tools back into the original box and close the lid.
    The original box was already so compact and obviously suited to the task. If I leave it to the movers, I can almost guarantee their weight will double because of the amount of paper they use.
    I did Google it, but could not find a resource that would show me how to repack this like the original box packer did (they must have had instructions, too, right?).
    Yes, I realize this is OCD.
    ​​​​​​Paul
    • 2812
    Paul,
    Sorry I can't help with the present challenge, but I've learned over the years that when the packaging appears to be complex and I intend to save the box for possible future storage of the tool, I take a picture of it before I start unpacking. It hasn't happened but a couple of times, but having a photo sure helps!
      I forgot which one you bought. Never the less, I would go quickly to HD or Lowes and buy a tool storage tote or box a little over one size larger than what came with yours. It is evident that the OEM box was for shipping only and not for daily usage.
      I have found my purchased tool boxes/tote boxes are very handy.
      • DerekShellman66
        Handtools only
        • Sep 2020
        • 3
        • New Jersey
        • Stihl MS461
        I have to report a fail on the ONE+ 🔋18-Volt Power Caulk gun. I had a lot of caulking to do at a rental house 🏚. I have a CH air powered gun but thought the battery unit would be less cumbersome.
        The Ryobi gets good reviews. My experience was disappointing👍
          I read the reviews several weeks ago on the Ryobi Caulk gun, both on HD and on Amazon. It had too many negative reviews for me to even consider. I usually look up similar tools under other brands and compare again. IF there is a easily noticeable difference, I run from it. The caulk gun from Ryobi is one such tool. It has not been perfected just yet.
          One other Ryobi 18V tool that I do not like but use it - The reciprocating saw. It does the job but it sure shakes a lot. At 73 my grip is not what it used to be and it shows on that tool.
          • Carlos
            • 1893
            • Phoenix, AZ, USA.
            I have an ancient B&D power caulk gun that just takes AA batteries. Works fine. Not super fast, but totally usable for large-ish probject. Just have to keep batteries fresh, and replace as soon as it slows down, which is subtle.
