Hi All
    • 22051
    Hi All
    Someone inquired via private mail if I was OK because I had not posted too much lately.
    Well, I'm OK, sort of. In December I tore my rotator cuff, badly, according to the surgeon, playing tennis and then fishing.
    I could not lift my right arm higher than my waist.
    I went ahead with a 3 week cruise to Australia and New Zealand avoiding carrying anything and living with one arm.
    I had surgery in March and it will take a long time to get back to normal... 8 weeks in a sling immobilized so it can heal and then I'm looking at 6-12 months rehab/PT.
    So very little woodworking... I just made a swing seat for the tree swing; the boys outgrew the baby seat. ANd that involved the Table saw, miter saw and drill press. Very difficut with jut one hand. I can grasp and turn with the fingers of the right but I can't lift or apply any pressure. THe doc says I don't want to tear it any while its healing.
    RIght now he said I could take off the sling for a bit at home. which helps in typing. Otherwise I have to type and mouse by hunting and pecking with the left and mousing with the left.
    I can't drive and its is very hard to eat left handed. Try pulling up your pants left handed alone. Sleeping is hard with a sling.
    That's why I have been relatively quiet.
    And the board's been pretty quiet, too.
    Loring
    • 8793
    It has been kinda quiet! Take care of yourself. Rest isn't always painless!
    • tfischer
      • 2349
      Take care of yourself. You're one of the few that (normally) keeps this place alive.
      • billwmeyer
        • 1868
        • Weir, Ks, USA.
        Take care and don't re-injure yourself! I've been down to one arm for about a year and a half due to a stroke. I know the difficulties! Good luck in physical therapy!
          • 2810
          Very sorry to hear of your injury, and certainly the time it takes to heal. But don't rush it, you certainly don't want to prematurely do something that will lengthen the healing process. Does your doctor recommend any kind of treatment or physical therapy that will help your mending? I just hope this isn't causing you any amount of physical discomfort, though I'm sure the restraint is hard enough.
          Wishing you well and healing soon,
          • Slik Geek
            • Dec 2006
            • 708
            • Lake County, Illinois
            • Ryobi BT-3000
            Glad to hear you are alright, albeit impaired. Hope your recovery accelerates!
            • oakchas
              • 432
              • Jefferson City, TN, USA
              BTDT, three times! One right, two left.. Rotator cuff repairs ain't fun. Prayers for a speedy and full recovery. My wife had completely torn 3 of the 4 tendons in hers and had less pain than I did with smaller tears... Go figure.
              • Jim Frye
                • 1359
                • Maumee, OH, USA.
                • Ryobi BT3000 & BT3100
                Ouch! Take care and take it easy. I just have bad knees. Doesn't interfere with woodworking, except for lifting stuff without using the back. Anyway, take it slow and heal fast.
                Jim Frye
                The Nut in the Cellar.
                • billwmeyer
                  billwmeyer commented
                  I've had both knees replaced. One of the best decisions I've ever made. If I hadn't done that I would have been completely incapacitated when I had my stroke.
                • 22051
                PT comes after this 8 week healing.
                Healing in the sling is not really painful per se but annoying as all get out between itching and heat rashes that get under the sling..
                not to mention itches in the good arm you can't scratch either.
                The 6-12 month PT is going to be tough, i think.
                  • 22051
                  Click image for larger version  Name:	20190403_160200_resized_1.jpg Views:	1 Size:	119.7 KB ID:	836468
                  Here's my swing project, the ropes were hanging for the old baby seat swing when the 4 y.o. grandson says grandpa can i swing? so it takes me a day to build this swing seat. miter saw, drill press, table saw. table mounted Router
                  you have to clamp the **** down before cutting and drilling. did you know that drill press levers are not on the correct side for lefties? or is the handle and trigger for a miter saw?
                  on the table saw, i could use a hold down shoe for the rips, but your left pushing arm has to reach over the blade...All three tools were awkward for one handers and made three times worse so for lefties.
                  table routing not so bad, small item like this, one hand OK.
                  i never knew there were so many obstacles for lefty wood workers.
                  Then i had to use the bolt cutters with one lever arm on the bench pushing down on the other lever arm with my good arm. i cheated a little and used the sling arm to stabilize it so it wouldn't flop over.
                  varnishing it today.
                    • 3119
                    Welcome to the 10%. Shopsmith can have the levers on either side, most cricular saws blow the dust right at you if you're a lefty. Buy an ergonomically incorrect miter saw so you can actually use it ...
                    Nice one handed project!
                    • gsmittle
                      • 2793
                      • St. Louis, MO, USA.
                      Yep. Being strongly left-handed is … challenging. When I was teaching my desk was set up left-dominate. Sometimes when I had a sub I'd come back to class and find all my desk stuff was moved to the right side.
                      Loring, hope you're feeling better and recover quickly. Remember us when you're a righty again.
                      g.
                      Smit
                      "Be excellent to each other."
                      Bill & Ted
                      • jabe
                        • 577
                        • Hilo, Hawaii
                        Take care and do the PT to help with mobility. I had surgery on both shoulders at different times and it took about 6 months to completely heal each shoulder. The PT was painful but no pain no gain.
                        Don't try to do so much now, take it easy have the wife & kids take care of you.
                          • 22051
                          I stated PT this week and my arm is sore from the exercises I have to repeat three times a day.
                          I'm going to get fat because the PT clinic is right around the corner from little CHinatown and I've scheduled all my PT for 10:00
                          The good news is that the PT guys says it shouldn't take as long as the Surgeon predicted... we'll see. Maybe he just meant I would learn all the exercises in a short time but not have to go in but have to do them for as long as the surgeon suggested.
                          But its great to be out the **** sling and be able to move some but I can see the arm is going to be sore a lot. Still not going to be lifting anything very weighty for a whille. Even a can of soda is a load to lift.
                            As gs and twistol said,..Welcome to our world! I am luck that I am close to being ambidextrous. I am left dominate but I throw right. I write and shoot pool left. Pretty much anything else either hand is good. Get comments about looking funny eating with my left hand and I just shrug my shoulders, switch to the right hand and ask them if they can eat with the left hand.
                            Had a rotator cuff done several years ago and was put in therapy a week after surgery. Back on the job delivering mail in about 8 weeks. I need to have it done on my right and I am putting it off. Pain or use isn't too bad and I refuse to be down through good riding weather. I was going to have it done in January but the wife was in the hospital. Like I said, that was YEARS ago and at 70 I'm sure it's going to take longer to heal this time around but the surgeon still says 2-3 months for recovery.
                            Take care, work hard in therapy and don't do anything to reinjure the shoulder.
