Take plywood deal?
    Take plywood deal?
    I am in need of a few sheets of decent shop grade ply and found a seller on craigslist who says she has 10 4x8 sheets of 11 ply 3/4 birch plywood. At this point I have agreed to $110 for 4 sheets but I wondered if I should grab the lot.
    Storage is always a pain but I will be building some new shop cabinets pretty soon. Soooo if its good stuff is this a good deal? Do I take all 10?
  • vaking
    • 1428
    • Montclair, NJ, USA.
    • Ryobi BT3100-1
    I don't know what "shop grade plywood" is and how much it goes for. I know that at HD cabinet grade pine plywood (23/32" thickness) is $30 per sheet and birch ply is over $45 per sheet.
    Alex V
    • russde
      • Aug 2013
      • 50
      If it looks good in person, I'd buy it all, I can't get it anywhere other than HD or Lowes around here and as vaking said it's pricey. ~$27/sheet it's a bargain if in 'new' condition.
      R
        • 22034
        R
        yep, sounds like a plan
        • Cochese
          • Jun 2010
          • 1988
          Shop grade birch around here from the lumber yard is anywhere from about $35-$45, depending on how much the last truck was.
          • woodturner
            • Jun 2008
            • 2049
            • Western Pennsylvania
            My local HD stocks various grades of birch - the "Baltic birch" is available in a lower grade at around $25/sheet, and the higher grade at around $45/sheet. So out the door with discounts, etc. the lower grade is around $20.
            Just pointing out that the subject plywood could be the lower end stuff. I use it for shop cabinets, etc. and it is OK, but I would not want to pay a premium for it.
              If it is flat and in good shape and if you have a place to store it that will keep it in the same condition why not buy it all.
                • 3761
                From the prices quoted it does not look like a landslide great deal, but I don't know if everyone is comparing apples with apples. This is 11 ply, is everyone else's? I don't believe I've seen 11 ply birch at my lowes and hd. If you can store it, buy it! Remember, plywood warps like plywood.
                capncarl
                • All Thumbs
                  • Oct 2009
                  • 322
                  • Penn Hills, PA
                  • BT3K/Saw-Stop
                  11 ply is likely import, I'd be careful with that stuff, the price is no bargain if you run into quality issues.
                    Well the jury is in and I guess it will be no surprise that this was NOT the good stuff.
                    Surface quality is pretty good and the plys seem to have minimal voids (could only see a few very small ones on the edges) but not sure it would be the most stable plywood you have ever worked with.
                    I would say its about the same as Lowes or borg HW ply. I bought the 4 sheets I need to use this weekend for ~$26 each (approx half retail). They will probably be fine but I doubt they would stay flat for long if stored for any length of time so I passed on buying the whole batch.
                    They guy said he gets them on a fairly regular basis so if they work out OK he will probably have more if and when I need them.
                    So the verdict is passable and reasonable value if you cut and join them quick but Baltic Birch or Apple Ply this aint!
                    • All Thumbs
                      • Oct 2009
                      • 322
                      • Penn Hills, PA
                      • BT3K/Saw-Stop
                      It is my theory that the inner plies of this imported stuff are fairly wet when the plywood is pressed, and this accounts for the twisting/bowing/delams we see. It would be nice if someone with a decent moisture meter would check the moisture of a fresh sheet some time.
