How to Clean Monitor Screens?
  • phrog
    • Jul 2005
    • 1796
    • Chattanooga, TN, USA.
    I've always cleaned the gunk (grease atomized from kitchen) from my monitor and tv screens with alcohol swabs. But those old monitors and tvs had glass screens. I don't think the alcohol would be a good choice on today's plastic screens. What do you guys use to clean those new screens? A simple dusting won't do it. Thanks.
    Richard
    This works pretty good.
      Or...you could mix up a spray solution of 50/50 distilled water and white vinegar, and use a soft dust free cloth.
        • 9524
        Step #1. Don't let them get that nasty...
        Step #2. Use wipes designed for electronics. I personally use the Endust ones with no problems http://www.amazon.com/Endust-Electro.../dp/B002SBB0SU
        Step #3. See step #1.
        • jdon
          • Feb 2010
          • 401
          • Snoqualmie, Wash.
          I use water/isopropyl alcohol ~50/50 with a microfiber cloth, with good results and no damage.
          • BobSch
            • 4385
            Whatever you decide to use, spray it on the rag, then wipe. Don't spray directly on the monitor, liquids and electronics don't mix well.
            Bob
              Thanks for mentioning that...I just plain forgot to do that.
              • bmyers
                • Jun 2003
                • 1371
                • Fishkill, NY
                • bt 3100
                Perhaps more baked foods might help
                • phrog
                  • Jul 2005
                  • 1796
                  Thanks, C'man. Now can I borrow your dog?
                  Richard
                  • phrog
                    • Jul 2005
                    • 1796
                    More than just my screens, I'm sure.
                    Richard
                    • phrog
                      • Jul 2005
                      • 1796
                      Thanks to everyone for all the suggestions. I guess I'll try on a dysfunctional monitor I have stored in the attic and see what happens.
                      Richard
                      • herb fellows
                        • New York City
                        + 1, that's what I use, never a problem so far.
                        There are different grades of micro fiber, you want to get the softest one possible (probably over pay for it a bit in an electronics store) and use one side till its too far gone, then the other, then replace the cloth..
                        At least the solution is cheap.
                        Of course, you do want to dust thoroughly first as anything solid in the dust becomes a scraping tool once you use a wet solution.
                        Also, always apply the wet solution to the cloth, not to the screen.
                          • 3756
                          I know that the white-out we use for spelling corrections sure does not come off easily.
                          capncarl
                          • woodturner
                            • Jun 2008
                            • 2049
                            • Western Pennsylvania
                            Either use the wipes formulated specifically for LCD screens or a soft, non-abrasive cloth, dampened with water (tap, filtered, or whatever, any drinkable water is fine) ONLY. A dampened paper towel can also be used (paper towels are non-abrasive). FWIW, clear tap water is what is used in the factory to clean the screens.
                            Be careful how you wipe - if the cloth or paper towel is not wet enough, it won't trap the dust particles. Wipe in straight strokes vertically, turning over a fresh surface each stroke. Then repeat in the horizontal direction. It's important to keep turning a new surface so that dust particles are not rubbed against the screen, which will cause scratches.
                            Alcohol, vinegar, and other solvents and acids should not be used as they will damage some of the plastic screen overlays over time.
                            Keep a cover on the screen when cooking - there is no good way to get grease off the screen.
                              Water, as in tap water is not recommended, as it contains dissolved salts, and can have a chlorine content. Distilled water should be used...with an equal mix of white vinegar. Paper towels can be too much of an abrasive medium for cleaning screens.
