put wristwatch in vaccum bag to suck out moisture?
    I went swimming with my watch and then I discovered a little condensation on the inside. It was in freshwater. I have vac pump and bag for veneering. Could I stick it in there to suck out the moisture?
    Don't think it would work to get out moisture with just the watch and a vac bag. Might add a bunch of rice to the bag then take the air out. The rice should absorb the moisture.
    • Daryl
      • 831
      I would try removing battery, leave it open and lay on dash of car in hot sun.
      • Cochese
        • Jun 2010
        • 1988
        Bowl of uncooked rice. That's it.
          It will dry out on its own.
            • 22084
            i would think the best success would be if you could take the battery cover off and put it in a regular (not microwave) oven at about 100-130 degrees for a while to bake out the moisture. Or take the cover off and put it in a sealed bag with a few silica gel packets.
            Either way you need an easy path for the water to get out, even a small amount of moisture will be hard to get back past the seal that leaked it.
            • gerti
              • 2233
              • Minnetonka, MN, USA.
              • BT3100 "Frankensaw"
              Rice should do, or some of those desiccant packs that come with electronics and some tools.
              • Charlie R
                • Jun 2007
                • 90
                Put it in your freezer overnight. No prep needed.
                  • 8803
                  Another vote for rice. Works well on cell phones dropped into water.
                  - the voice of numerous experiences!
