This is bad, this is very bad...
    • 9554
    3+ hours into cleaning my shop, and I still can't see the floor... I am FINALLY purging the pull out scraps of molding that I used to for sizing when I trimmed out the laundry room, but jeeze, where did all this junk come from?
    On the plus side, the air compressor, the shop vac, the Thien Trash Can separator and all my screwdrivers are back where they belong...
    I have bits and pieces of about 6 projects sitting there, just waiting to be completed, or at least stored carefully... Including some scroll work I have been on and off with since I got my scroll saw back in, what was it January?
    I need to take better care of my shop!
    • 22058
    I wonder if i still have a floor???
      • 9554
      I went back out there for a while. I found the floor. But what the *#$% is that spill?!
      Oh yeah, Minwax Golden Pecan. Looks like I knocked a can over while cleaning... That's going to be fun to mop up!
      Now the fun part. I have 10' stock from Clarks, and only 8' 6" of space in my lumber rack before I run into the tool stacker... I really don't want to cut this stuff down, but it looks like I have to!
        I'm always amazed at what I find when I clean the shop.
          I clean the shop then forget where I put things away!
          • ironhat
            • 2553
            Boy did you hit the nail on the head! I've learned that moving tools or accessories from where they have been for the past 10 years spells disaster for a couple of years. You spend more time looking for the masking tape than you spend on the actual project!
            Blessings,
            Chiz
              • 9554
              My square! I found my square! And where did all those calipers come from?
                • 8795
                I have two 3-piece HF tool chests purchased last fall and still have too many small tools to fit in. I need one more! But for once, I can find most of my hand tools at any one given moment!
                It sure is nice to be able to find the tools - instead of having to go buy one cause you need it NOW and can't find it at home!
                • mpc
                  • 1018
                  • Cypress, CA, USA.
                  • BT3000 orig 13amp model
                  Can you stick them in the rafters of the shop or in the garage? That's what I did with my longer stock. I didn't want to make the lumber rack TOO big! Or use a few metal "L" brackets to make a quick-n-dirty "shelf" above the garage door - attach them to the beefy header board and take advantage of typically wasted space.
                  mpc
                    • 9554
                    I think I can stash the 10th ft stock on top of my library cabinet. It's 8 ft long with nothing next to it...
                      My problem is just the opposite. I'm generally good about storage between projects, and know where I keep things. However, I have far too many convenient surfaces in the shop to use as temporary resting place for tools during a project - i.e., any level surface, usually other than one of my two workbenches. Table saw, router table, RAS table, planerr table, lathe workbench - if I pass by on my way to get something else, I may just leave a tool, measuring or marking instrument absentmindedly and have to retrace my steps to find it again.
                      • jking
                        • 972
                        • Des Moines, IA.
                        Maybe if you sold the extras you bought when you couldn't find your tools, you wouldn't need the third tool chest.
                          I always tell myself, "OK, after this project, I'll clean," but then another mini-project comes along which has me thinking, "I can knock this one out quick; I'll clean later." Snowball effect. I am a terrible procrastinator. I am starting to think the reason I don't clean is that I will discover that I really don't have any more room to grow and I'll have to start selling off big tools.
                          Paul
                            • 8795
                            I am already thinking along those lines. But instead of selling, I made up a tool box for one of my grandsons a couple of months ago, and he uses those tools already around his house. He is naturally observant of practical things and items with nails and screws and bolts and nuts. He knows which pliers to use for which job, when to use a cresent wrench instead, and more! He already fixes things that his dad doesn't, moves pictures, centers them and re-hangs them - just not into electrical yet. And he is only 7 years old. He was over here two weeks ago and weeded my garden with out even asking, and he did a great job! Only 7 years old!
                            My extra tools go to him!
                            • jking
                              • 972
                              • Des Moines, IA.
                              ^^^^That is great stuff. Great use of extra tools.^^^^
