"Known To CAlifornia...
    Is there anything they consider safe?
    This was on the plywood subflooring I put down.
Name:	sturdifloor warning.jpg
    Your safe Don, unless of course you cut that plywood! Apparently in California your not supposed to cut plywood or any wood for that matter... must be why it's so expensive to build there.
    • greenacres2
      • Dec 2011
      • 633
      • La Porte, IN
      I was in CA for the first time a few weeks ago--Pomona for the NHRA drag race. The number of signs i saw similar to that around the race track was amazing!! Wasn't sure if the fences were there to control the spectators or as a place to hang the signs.
      Now they just need to add a notice below that warning "the ink used to print the above notice is known by the state of California to cause..." then a warning about that warning...ad infinitum!!
      earl
        Maybe its the air off the Pacific.
          • 9560
          you'll be fine unless you try doing anything in California, then you'll get cancer...
          • BeauxTi
            • Jan 2012
            • 108
            • Georgetown Texas
            • Ryobi BT300
            Sooooo, it's California that causes cancer?
            Beaux Ti -
            If you see a Bomb Tech running, follow him....
            • jussi
              • 2162
              Several types of oil finishes are also banned here and borg won't cut mdf,osb, anymore. I've heard plywood will be next. Which I assume will make all their panel saws useless.
              • BeauxTi
                • Jan 2012
                • 108
                • Georgetown Texas
                • Ryobi BT300
                Hey - the lemon-aid for those lemons - you might get a real good deal on a Used panel saw!!
                Beaux Ti -
                • jackellis
                  • 2638
                  • Tahoe City, CA, USA.
                  One of our esteemed legislators has sponsored a program called "There Oughtta Be a Law". As if we don't have enough badly conceived, contradictory laws in this state.
                  Then again, I'm an engineer and most legislators are lawyers. The two professions employ vastly different problem solving methods.
                  • radhak
                    • 3061
                    • Miramar, FL
                    • Right Tilt 3HP Unisaw
                    There's truth in advertising:
                    and then there's plain truth :
                    - Aristotle
                    • RAFlorida
                      • 1179
                      What about:
                      "...known to the state of California that coitis causes cancer and..."
                      edit: sorry if this offends, but the state of California takes thing way too far, just like I did.
                      • tommyt654
                        • Nov 2008
                        • 2334
                        ROFL, There oughta be a sign stating lawyers and politicians are known carcinogens and the leading cause of cancer and all other known disease's
                        • All Thumbs
                          • Oct 2009
                          • 322
                          • Penn Hills, PA
                          • BT3K/Saw-Stop
                          While funny, I'm afraid that all these warnings have made the public somewhat immune to warning labels.
                          • RAFlorida
                            • 1179
                            All Thumbs just said it all!
                            All those warning signs and we just ignore them now. One time I read that a person can drink too much water and suffer from it. Now that ONE just requires good old fashion common sense.
                            • TB Roye
                              • 2969
                              • Sacramento, CA, USA.
                              The Legislature in California suffers from Dementia. We are trying to make them part time.
