Public Bathrooms
    Public Bathrooms
    I made a stop at HD to pick up some AC filters. Grabbed a cart and started to meander towards the rear of the store. I got about halfway down an isle when all of a sudden I got an urge to go to the bathroom.
    Actually it was more than an urge. It was one of those poop warnings that you only get about 3 times a year. I thought it might be just a false alarm, but decided not to try a test blast just in case it was for real.
    It was so bad I didn't even want to take another step. I just had to stand perfectly still and grip the cart handle. I just happen to be in the wallpaper isle, and I just stood where I was and pretended to be looking at patterns. I was motionless, legs quivering, sweating slightly, and leaving my finger impressions in the plastic handle while staring at pink and blue flower patterns.
    I was concerned about how I appeared. I must have looked like I was bracing for an earthquake. Now, it's times like this that the bathroom is at the far end of the store. I'm not crazy in favor of public bathrooms in the first place. It seems that the people that maintain them are deaf, dumb, and blind. They never heard of soap. I've used holes in the ground that are cleaner than some public bathrooms I've been in.
    Besides, public bathrooms usually have a two foot roll of toilet paper housed in a highly engineered stainless steel dispenser that gives you one 4" x 4" square of single layer paper at a time. What the heck good is that?
    Anyway, for as fast as the urge came on, it went away. I was thinking...where does it go? After I regained some senses, and color came back to my face, I made it to the filters, and rolled on to the checkout. As I drove away, my only thoughts were to get home as soon as possible. There's no place like home.
    Since having a few bouts of diverticulitus, I have adopted a very high fiber diet plus I take a fiber suppliment. When that feeling grabs ahold of me, I run-not walk- to the closest bathroom. Fortunately, that feeling usually come early in the morning soon after I get up.
    • Hoakie
      • Feb 2007
      • 382
      • Iowa
      Amen about public toilets....only use them in dire emergencies for #2. I have several "Safe" toilets at work to operate with. I don't like doing the business next to someone so I find ones with a single stall if i can.
      John
        Did it occur to you that the display crappers in the bath department might have been closer? If you didn't at least have a flash thought of this, then you didn't have a real emergency...
          OMG!!!!! LMAO!!!!! I better check my shorts. Amen to public bathrooms. I, too, have my safe zone at work.
            • 22056
            jeez, you guys are anal (pun intended).
            • gsmittle
              • 2793
              • St. Louis, MO, USA.
              At my work, the safe zone is the faculty restrooms. You don't want to go into the student restrooms unless it's truly an emergency—you'll get a contact high from the …um… fumes.
              I must be weird; I don't really have much of a problem with most public restrooms, not even in New Jersey. OTOH, any port in a storm, so to speak.
              g.
              Last edited by gsmittle; 07-14-2010, 05:48 AM. Reason: Added poke at NJ for no reason.
              Smit
              "Be excellent to each other."
              Bill & Ted
                Some public bathrooms are OK IMHO. Work is fine for me (although one is better than the other for #2). Airport is sometimes OK - and often necessary. Hotels are OK generally. Planes only when really necessary for #2.
                My son got picked on in grade school - stupid kids throwing stuff over the stall walls - and now he almost won't go away from home. He is 27 so it made a pretty long lasting impression.
                I do not like to "go" at Home Depot, I don't think I've ever even found the restroom at Lowe's and I try to avoid restrauants, quick service or otherwise. But sometimes you have to do what you have to do.
                  I don't think anyone can beat the bathroom scene in Trainspotting, though. That really was "doo" or die.
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    Sometimes we just don't know what gets into us, but sure can tell when it's time to come out! Thanks for the morning laugh!
                    For those that haven't read it or would like a refresher..."How to Poop at Work"
                    • smorris
                      • Apr 2003
                      • 695
                      • Tampa, Florida, USA.
                      I'll be back in a few minutes...
                      • natausch
                        • Aug 2009
                        • 436
                        • Aurora, IL
                        • BT3000 - 15A
                        I once got busy in a "burger king" bathroom.
                        Seriously though, outside of a bathroom that has hot fecal matter on the seat I'm fine using public restrooms.
                        • gsmittle
                          • 2793
                          Lemme guess…you worked there and it was your turn for latrine duty?
                          g.
                          Smit
                          Bill & Ted
                          • Kristofor
                            • 1331
                            • Twin Cities, MN
                            • Jet JTAS10 Cabinet Saw
                            All things being equal I'll avoid the "public" public restrooms, but work, hotels, friend's are all fine. I do have a couple preferred choices at work (as everyone should)
                            On a similar note, do you know how to pick the right urinal to use? Another old link but still an important skill to have http://www.onlinegames.net/games/113...inal-game.html
                            • SHADOWFOX
                              • 1232
                              • IL, USA.
                              • DELTA 36-675
                              This thread made me laugh so hard because it just reminded me of what happened to me this weekend when I went to the grocery store. I was at the usual stop at the magazine isle checking out woodworking mags then a sudden threat of unstoppable gas but luckily the one guy that was in the magazine isle was walking away and after checking to make sure nobody else was there I went ahead and released it. Then 2 seconds later I hear a voice calling out my name, I turned around and walking towards me was my neighbor's wife and boy you should have seen the look on her face when she caught a smell of it. I immediately blamed it on the guy that walked away.
                              Chris
