Chinese thread size
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    14 thread is an oddball. Glad you were able to get it fixed.
    • scmhogg
      • 1839
      • Simi Valley, CA, USA.
      Lee Valley has a neat thread checker.
      http://www.leevalley.com/hardware/pa...00&cat=3,41306
      Steve
        • 22108
        that is a weird size, most screw/bolt sites I went to had only up to #10 and then went fractional, 1/4, 3/8 etc,
        Apparently the ANSI #12 and #14 sizes are very old and have fallen into disuse. THe UNF (fine thread) are even rarer than the UNCs (coarse thread) usually.
        Makes you wonder what they were thinking when they designed that thing (I'm sure fairly recently).
        Or they just saw the standard spec in the machinery handbook and used it when a 1/4-28 would have been the practical choice.
        P.S. I'll bet the LeeValley thread checker doesn't have #14... the description says 10 UNC and 10 UNF sizes 1 thru 1/4
        which would be the common 1,2,3,4,5,6,8,10,12 and 1/4
        • phi1l
          • Oct 2009
          • 681
          • Madison, WI
          #12 is pretty common, but I don't think I have ever seen a #14 screw..
          • cwithboat
            • Jan 2008
            • 614
            • 47deg54.3'N 122deg34.7'W
            • Craftsman Pro 21829
            I did not find a thumb screw. What I found was a set screw. I have not checked the size, 14 was what it said on the box. Next time I am in Bremerton I will stop at Tacoma Screw and have them check it and see if they have a thumb screw.
            regards,
            Charlie
            Rudyard Kipling
            • Mr__Bill
              • 2096
              • Tacoma, WA
              There is a Tacoma Screw in, well, Tacoma. It's just off of 16 on Center Street, an easy off easy on kind of thing. One of the things I really like about the place is when you walk in clueless to what you need is called they assume that your ignorant not stupid and will then proceed to educate you, often with great delight in being able to tell you about all the different things they have.
              • sscherin
                • 772
                • Kennewick, WA, USA.
                I love Tacoma Screw.. They have opened stores all over the PNW.
                http://www.tacomascrew.com/locations
                They know me all to well at the Pasco, Wa store..
                I'll walk in with a bag of screws, they help me size em and find what I need..
                The prices can't be beat either..
                William's Law--
