Chinese thread size
  • cwithboat
    • Jan 2008
    • 614
    • 47deg54.3'N 122deg34.7'W
    • Craftsman Pro 21829
    Chinese thread size
    I ordered a basket for my rotisserie on my BBQ. The thumb screws were left out of the shipment, so I called the source and requested screws. I thought, while waiting for a package I would check and see if I could find a match to the basket at the local h/w store. I (and two employees) could not find a screw to fit the threads on the basket. 1/4-20 was too big #10 was too small, 6mm was too big, 5mm too small. The basket was made in PRC. What kind of weird thread sizes do the Chinese use?
    regards,
    Charlie
    Rudyard Kipling
    • 22108
    Almost exclusively metric. Some SAE for export stuff.
    Maybe it was painted after drilling and tapping so the hoel appears to small until you screw thru the paint...
    Ince nothing else has to attach to this hole, I would personally think about drilling the hole one tap size larger and tapping for a (maybe) 1/4-20 SAE thumbscrew or fastener.
    that would take a #7 tap drill or ~13/64" (.201")
    • guycox
      • 360
      • Romulak, VA, USA.
      Whitworth? I used to have them on my Austin Healey 100-6 drove me nuts. As I recall a 1/4 w was between a 1/2 and 916 -- almost impossible eyeball it..
      Guy Cox
      Life isn\'t like a box of chocolates...it\'s more like a jar of jalapenos.
      What you do today, might burn your butt tomorrow.
      • phi1l
        • Oct 2009
        • 681
        • Madison, WI
        Did you try a #12? ... Also there is a coarse & fine thread pitch.
        • cwithboat
          • Jan 2008
          • 614
          Did not try #12. Did not have one at the store. I will have to search around. It is most likely a fine thread. By the time I find a #12 thumb screw maybe I will receive the appropriate ones.
          Thanks for all the suggestions and advice.
          regards,
          Charlie
          Rudyard Kipling
          • sscherin
            • 772
            • Kennewick, WA, USA.
            Take it to Tacoma Screw..
            If they don't have it they can find one..
            90% of the time they will have what you need in stock..
            If your location is correct the closest one is in Bremerton
            http://www.tacomascrew.com/locations
            Beware.. you may end up walking out with a few new screwdrivers.. I always do.. it's like candy!!
            When it comes to metric there are many pitches.. My Motorcycle has em all.. 1mm,1.25mm 1.5mm
            Even one little superfine M8x.5mm on the idle screw..
            William's Law--
            • Rich P
              • Apr 2003
              • 390
              • Foresthill, CA, USA.
              If you figure all of their tooling came from the US or Europe (and maybe some old British stuff), they would have learned on and stuck with those standards, at least IMHO. Nowadays they are fooling around with their own "local" technical standards to try to freeze out the ROW, but I don't think they would do this with something as simple as a screw on a barbee.
                Rich, you talk about standards, yet there are SEVERAL different bolt standards, and I would LOVE to find a list of them.
                I believe I found ONE book that covers them (including some of the harder to find automotive ones), but I haven't found it yet.
                • sscherin
                  • 772
                  Metric
                  http://en.wikipedia.org/wiki/ISO_metric_screw_thread
                  Whitworth
                  http://en.wikipedia.org/wiki/BSW
                  British Standard Fine
                  http://en.wikipedia.org/wiki/British...rd_Fine_thread
                  British Standard Cycle
                  http://homepages.tesco.net/~A10bsa/bscbot.htm
                  British Association screw
                  http://en.wikipedia.org/wiki/British..._screw_threads
                  British standard pipe thread
                  http://en.wikipedia.org/wiki/British...rd_pipe_thread
                  NPT
                  http://en.wikipedia.org/wiki/National_pipe_thread
                  UNC/UNF/UNEF
                  http://en.wikipedia.org/wiki/Unified_Thread_Standard
                  William's Law--
                  • cwithboat
                    • Jan 2008
                    • 614
                    Of course. I should have thought of that immediately. Been there. Done that. Thanks for kicking my brain into gear.
                    regards,
                    Charlie
                    Rudyard Kipling
                    • jking
                      • 972
                      • Des Moines, IA.
                      Machinery's Handbook is the reference I go to when I need to know the specs on a thread. Of course, it costs some serious $$, but, it's not the type of reference the average guy buys just to have around.
                      • phrog
                        • Jul 2005
                        • 1796
                        • Chattanooga, TN, USA.
                        When I first saw the title of this thread, I thought it had something to do with silk.
                        Richard
                          That book has been on my list for QUITE a while. I am just looking for a bargain (estate/garage sale, etc.).
                          The problem, is the weird, J? spec (don't remember the proper term now), where it is used in automotive (odd HEAD size, to threads). It isn't Whitworth (that would be too simple).
                          Thankfully, MOST stuff I deal with is pretty standard, either SAE or Metric. It is when you come up with one of these weird things, it can drive you up a wall.
                          • sscherin
                            • 772
                            There are dozens of copies up on Ebay..
                            24th edition Buy it now $25 shipped
                            http://cgi.ebay.com/24th-EDITION-MAC...item439d115583
                            Watch out for the ones listing the pocket guide as the full 2700 page book
                            William's Law--
                            • cwithboat
                              • Jan 2008
                              • 614
                              Just to put an end to this. It is a #14 fine thread.
                              regards,
                              Charlie
                              Rudyard Kipling
