Friends have moved into house where the previous residents had a cat who liked a corner of the livingroom to do her business. They tore up the carpet but the pee is soaked into the subfloor. Tearing up the subfloor is one option past the last option. I thought of soaking bleach into the area but I'm open to any other suggestions.
Cat Pee In Subfloor
Cat Pee In Subfloor
http://richardspensandthings.blogspot.com/Tags: None -
I understand that vinegar will help neutrilize the smell.
Bill"I just dropped in to see what condition my condition was in."-Kenny Rogers -
The enzyme-based pet urine removers work okay (and they don't smell as bad as bleach). You have to give them a little time to work. You should be able to pick some up at a pet store. A black light would also help you find all of the spots to make sure you get everything.- Dennis
"If your mind goes blank, don't forget to turn off the sound." --Red Green
and yes, it's a potato.Comment
For a kickback demonstration video http://www.metacafe.com/watch/910584...demonstration/Comment
I have used the pet urine remover / black light trick. It works. Kind of slow, but it works...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
Enzyme-based pet urine removers work, they do take some time. A carpet cleaner guy told me that putting a really heavy coat of poly over the spot will seal the odor in, however he cautioned that you should use only oil based poly and using the other will just allow the smell to surface. I put a whole gallon on the sub-floor where a dog had used the carpet as a bathroom. I just poured it on and spread it with a squeegee. It sealed in the smell. In the basement on the concrete I used the enzyme-based stuff and then left it with the new tenant. She said it took about 3 months and several more gallons to get it where the smell was gone.
BillComment
Concur with the suggestions for the enzyme products. Bleach does not neutralize the base cause for the odor. It only disinfects, and then remains to cause problems of its own. The enzyme stuff is formulated specifically for this use, and I have had better-than-average luck with it in the past.Comment
I had this problem when we moved into our house 35 years ago. The 70 year old oak flooring had a black stain 2 1/2' in diameter. We tried everything then available.
Wound up tearing up a large chunk of floor and subfloor and replacing it. Still, even now on a warm, humid day we get a faint reminder of the former tenants.
of the warning labels on tools can be traced back to things I've done...Comment
I may be wrong, but soaking the sub-floor could actually warp or damage the sub-floor couldn't it? Also, do your friends have any pets or plan on getting one? Even with the smell gone to our noses, a dog or cat will smell it right away and probably use the same spot. I know it is a pain, but I would replace that part of the sub-floor.
DaveDave
BT3000
"98% of all statistics are made up"Comment
Why can't you tear up that part of the sub floor?
I have done this before, and it really isn't that hard.
Even with all the suggestions here - the smell might come back... for example, on humid days.
At that point, the nice, new flooring will be down, and it will be twice as painful to rip it up and replace the subfloor.
A whole sheet of new subfloor would cost less than a gallon of "nature's miracle" enzyme stuff.Comment
The best I've used are the Oxygen based cleaners, Hydrogen Peroxide. A Canadian source is here: http://www.greenforlife.ca/downloads...stBrochure.pdf. Much cheaper than buying water from the pet store. Chlorine Dioxide also works well, but it will do you serious harm if not used properly.Comment
Lots of great tips guys, thanks.
I should have mentioned before that these people will only be renting and the landlord is giving them a free month plus expenses if they can take care of the problem before the new carpet comes in.From the "deep south" part of Canada
http://richardspensandthings.blogspot.com/Comment
Shellac can be pretty good at sealing in odors. The enzyme cleaners can be hit or miss. Nature's Miracle is said by some to not be as good as it once was and is probably the most popular brand, but there are many others.
JimComment
I used the bleach approach, dumped about a gallon of it on the sub floor (plywood) and let it set there for a few days (the house was unoccupied at the time, the area measured about 4' square. Worked like a charm.
My cats never used that spot again. The replacement flooring was Pergo, not carpet as before. Maybe that had something to do with it.
I'ts cheap enough to try.
Bruce"Western civilization didn't make all men equal,
Samuel Colt did"
