Washer w/ no center hole?
    I need a washer with no center hole. I'd like it to be approx. 1/2" in diameter. Maybe 1/32" thick (thickness not too critical).
    I tried looking on McMaster for some sort of undrilled washer but couldn't find anything.
    I tried using a dime, but it is a little large for my needs.
    Any ideas?
  • sparkeyjames
    • 1087
    • Redford MI.
    A punch out from a metal electrical box. Then cut/grind it down.
      Try searching from metallic discs, or flat plugs or other name.
        Does it have to be steel? Maybe a plug cutter & some aluminum or brass sheet stock might work.
          Sparkyjames, that will be my last resort.
          Lee, the discs at McMaster are enormous.
          Pelligrini, steel would be ideal. Aluminum/brass may be too soft.
          Here is a question: Are there any foreign coins smaller than a U.S. dime? Anything made out of steel would be ideal.
            What do you have planned for this ity bity disc?
              Check the local auto supply that carries body shims for lining up fenders... etc. They came in about any thickness you want. Probably don't sell one individual so check with a auto body shop if you know someone and I would bet they would just give you one.
              Good luck...
                I know that you don't want to go this route but it might be helpful if you need a long term supply: Grizzly has a manual/hand hole punch set that has several sizes to punch a hole close to the size. They are for punching holes but if the plug is cleanly cut, it might do what you want.
                http://www.grizzly.com/catalog/2009/Main/568
                Besides, this would be a good chance to get a new tool!
                • Tom Slick
                  • 2913
                  • Paso Robles, Calif, USA.
                  • sears BT3 clone
                  I think what you are looking for is called a "blank" or informally a "slug". I don't know where to buy one but if you've got any friends with a metal lathe and a parting tool it lt would take seconds to make.
                  • drillman88
                    • Dec 2007
                    • 572
                    • Southeast
                    Can you get a piece of round barstock or rebar and cut in a bandsaw or with a die grinder?
                      You don't say what the constraints are:
                      Quantity, price, thickness, flatness, tolerances.
                      If I wanted washers and price was no problem, I'd go to Boker's, a washer/stampings specialist.
                      http://www.bokers.com/custom_washers.asp
                        Quantity, price, thickness.
                        They don't seem to sell blanks IOW, ones with no holes.
                          http://www.teejet.com/media/be30834f...LoRes_p070.pdf
                          • Wood_workur
                            • 1914
                            • Ohio
                            • Ryobi bt3100-1
                            Disc
                            Alex
                              Originally posted by Wood_workur
                              Disc
                              yup, that would be it.
