ON a dell laptop, with xp pro, all that does is show the drop down box for format.?
useful tip - typing "degrees" symbol °
Last edited by herb fellows; 05-26-2009, 09:22 AM.You don't need a parachute to skydive, you only need a parachute to skydive twice. -
Let's try again. ° º What is the difference between those?
Leave out the u, just use ctrl and shift, then type.
U ONLY worked, with the degree symbol, otherwise, it does ¢ I believe that will show the cents symbol, underlined.
When I typed this long thing before, using ones I would use, at some point I found one that deleted everything I typed (I thought I just went to far down).
¼ ½ ¾ ® © ± ² ³ All these are the most needed, by me. Thanks for the tips, and this time I didn't hit some delete key.Last edited by LinuxRandal; 05-26-2009, 10:16 AM. Reason: Added a space, don't like the way it read.She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
The ° symbol is %%d in Autocad. The newer versions will substitute the symbol in the actual text for most text styles now.ErikComment
For a kickback demonstration video http://www.metacafe.com/watch/910584...demonstration/Comment
For us enlightened Macintosh users, there's no need to remember arcane strings of numbers.
Shift-Option-8 gives you the °
Shift-Option-[hyphen] gives you an em dash (—)
Option-U then a vowel gives you an umlaut (ö, ï, ä, ü)
An en dash (–) is Option-[hyphen]
a bullet (•) is Option-8
My personal favorite is the ellipsis (…), Option-semicolon
There's tons more, all standardized, except some typefaces are missing some characters…
g.Smit
"Be excellent to each other."
Bill & TedComment
Footer Ad
