Computer ?
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    I'm sorry I've been slow about posting, I have been redoing hardwood floors. Here is
    what You both asked for, I hope, Their was nothing in the dial up and virtual settings
    box. Bill
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : wwbb
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Wireless Network Connection 3:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Compact Wireless-G USB Adapter
    Physical Address. . . . . . . . . : 00-22-6B-A5-0A-84
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    Autoconfiguration IP Address. . . : 169.254.20.193
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . : 169.254.20.193
    Ethernet adapter Local Area Connection :
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection
    Physical Address. . . . . . . . . : 00-07-E9-D5-3B-3C
      Hi Dud,
      The IP info for your wireless is the Windows default. That means it is not getting an IP address from the router either because the DHCP server is not enabled on the router or it is not connecting to the router. Bring a laptop or similar over that you can plug into the router via a network cable. Then you can verify whether her desktop is connecting (the router will have an option to show you connected devices) andyou can check whether certain machines are allowed to connect wirelessly. You can also check to see if DHCP is enabled. By default it should be. My guess is the machine is not actually connecting to the router, rather than DHCP not being enabled.
      What brand/model # router is it?
      • DUD
        • 3309
        Thanks David
        I'll check this morning. Bill
        • just started
          • Mar 2008
          • 642
          • suburban Philly
          Did you try the passphrase in hex? I have spent hours troubleshooting on more than a few systems and they all ended up with that problem.
