Let's hear it for the Deer
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    I had this idea that I was going to rope a deer, put it in a stall, feed it up on corn for a couple of weeks, then kill it and eat it.
    The first step in this adventure was getting a deer. I figured that, since they congregate at my cattle feeder and do not seem to have much fear of me when we are there (a bold one will sometimes come right up and sniff at the bags of feed while I am in the back of the truck not 4 feet away), it should not be difficult to rope one, get up to it and toss a bag over its head (to calm it down) then hog tie it and transport it home.
    I filled the cattle feeder then hid down at the end with my rope.
    The cattle, having seen the roping thing before, stayed well back. They were not having any of it.
    After about 20 minutes my deer showed up -- 3 of them. I picked out a likely looking one! , stepped out from the end of the feeder, and threw my rope. The deer just stood there and stared at me.
    I wrapped the rope around my waist and twisted the end so I would have a good hold. The deer still just stood and stared at me, but you could tell it was mildly concerned about the whole rope situation.
    I took a step towards it...it took a step away. I put a little tension on the rope and then received an education.
    The first thing that I learned is that, while a deer may just stand there looking at you funny while you rope it, they are spurred to action when you start pulling on that rope.
    That deer EXPLODED.
    The second thing I learned is that pound for pound, a deer is a LOT stronger than a cow or a colt. A cow or a colt in that weight range I could fight down with a rope and with some dignity.
    A deer -- no chance.
    That thing ran and bucked and twisted and pulled. There was no controlling it and certainly no getting close to it. As it jerked me off my feet and started dragging me across the ground, it occurred to me that having a deer on a rope was not nearly as good an idea as I had originally imagined.
    The only upside is that they do not have as much stamina as many other animals.
    A brief 10 minutes later, it was tired and not nearly as quick to jerk me off my feet and drag me when I managed to get up. It took me a few minutes to realize this, since I was mostly blinded by the blood flowing out of the big gash in my head. At that point, I had lost my taste for corn-fed venison. I just wanted to get that devil creature off the end of that rope.
    I figured if I just let it go with the rope hanging around its neck, it would likely die slow and painfully somewhere.
    At the time, there was no love at all between me and that deer. At that moment, I hated the thing, and I would venture a guess that the feeling was mutual.
    Despite the gash in my head and the several large knots where I had cleverly arrested the deer's momentum by bracing my head against various large rocks as it dragged me across the ground, I could still think clearly enough to recognize that there was a small chance that I shared some tiny amount of responsibility for the situation we were in, so I didn't want the deer to have to suffer a slow death, so I managed to get it lined back up in between my truck and the feeder - a little trap I had set before hand...kind of like a squeeze chute.
    I got it to back in there and I started moving up so I could get my rope back.
    Did you know that deer bite? They do! I never in a million years would have thought that a deer would bite somebody, so I was very surprised when I reached up there to grab that rope and the deer grabbed hold of my wrist.
    Now, when a deer bites you, it is not like being bit by a horse where they just bite you and then let go. A deer bites you and shakes its head -- almost like a pit bull. They bite HARD! and it hurts.
    The proper thing to do when a deer bites you is probably to freeze and draw back slowly. I tried screaming and shaking instead. My method was ineffective.
    It seems like the deer was biting and shaking for several minutes, but it was likely only several seconds.
    I, being smarter than a deer (though you may be questioning that claim by now) tricked it. While I kept it busy tearing the bejesus out of my right arm, I reached up with my left hand and pulled that rope loose. That was when I got my final lesson in deer behavior for the day.
    Deer will strike at you with their front feet. They rear right up on their back feet and strike right about head and shoulder level, and their hooves are surprisingly sharp.
    I learned a long time ago that, when an animal -- like a horse -- strikes at you with their hooves and you can't get away easily, the best thing to do is try to make a loud noise and make an aggressive move towards the animal. This will usually cause them to back down a bit so you can escape.
    This was not a horse. This was a deer, so obviously, such trickery would not work. In the course of a millisecond, I devised a different strategy. I screamed like a woman and tried to turn and run.
    The reason I had always been told NOT to try to turn and run from a horse that paws at you is that there is a good chance that it will hit you in the back of the head. Deer may not be so different from horses after all, besides being twice as strong and 3 times as evil, because the second I turned to run, it hit me right in the back of the head and knocked me down.
    Now, when a deer paws at you and knocks you down, it does not immediately leave. I suspect it does not recognize that the danger has passed. What they do instead is paw your back and jump up and down on you while you are laying there crying like a little girl and covering your head.
    I finally managed to crawl under the truck and the deer went away.
    So now I know why when people go deer hunting they bring a rifle with a scope so that they can be somewhat equal to the Prey.
  • reddog552
    • Dec 2006
    • 245
    • Belleville Il.
    • Bt3000
    Deer
    I think you ran across one of them trained attack deer
    The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
      Perhaps you should consider harvesting your venison at the local market from now on...
      • GoFish104
        • 67
        When I was 8 or 9 my Dad & I were helping w/ a spring round up. We came across an old buck that had been wounded but not killed. It was in pretty bad shape & surely would have soon starved to death so it was decided to team rope ( 1 rope on the head & another on the back legs) this buck & cut his throat to put him out of his missery. That dang old half dead deer almost killed a good horse before they got the second rope on it. Maybe it wasn't as close to death as we thought. Jack
          Bill, you don't have any extra venison steaks, do you?
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            I think the same thing happened to Pappy about a year ago.
              • 10481
              That was worth reading again!
              • cwithboat
                • Jan 2008
                • 614
                • 47deg54.3'N 122deg34.7'W
                • Craftsman Pro 21829
                It seems to me that there is a lesson here. Most of the deer harvested here-abouts are defeated while the great white hunter is inside the pickup truck doing 35 mph.
                regards,
                Charlie
                Rudyard Kipling
                  • 3111
                  The last time I took out a deer it was surprisingly easy. The woman at the Hertz rental counter, however, acted much more like your deer upon seeing the remains of the Buick.
                  • Caddis295
                    • 51
                    • Williamson, GA.
                    I am still laughing!
                    Dud,
                    While I believe that your thought process was sound from a human stand point, that deer definately introduced you to MURPHY! I never underestimate the self preservation instinct of animals. I am still giggling! Man, I am sorry to be enjoying your painful experience. Hope you heal up fast. I do believe Pappy did this last year? Thanks for the laugh!
                    Dino "Woodbin Pirate" Gutierrez
                    "The greatest glory is not in never falling but in rising up every time we fall.”
                    • lebomike
                      • Jan 2008
                      • 146
                      • Pennsylvania
                      I'm sitting here trying to stop laughing and type a response. I'm sure you will NEVER try that again. Thye sure are lively critters when roped.
                      "The power of kindness is immense. It is nothing less, really, than the power to change the world."
                      • jackellis
                        • 2638
                        • Tahoe City, CA, USA.
                        I've got to say I did something almost as...foolish this fall.
                        Joined some friends for a big game hunt on a game ranch in a land far away. It's the last day and my friend (photo) shoots a large african antelope called a kudu. They have enormous antlers and weighs up to 700 pounds. Somehow he wounded the beast instead of killing it and the critter started to run off into the brush. Light's fading, the farmer is yelling at us to track the thing down and I finally do find its tracks. Except that unlike everyone else, I'm unarmed.
                        Lucky for me someone else found it first. Next time, I will have a firearm in hand.
                        • Crash2510
                          • 830
                          • North Central Ohio
                          that is one of the funniest things i have ever read
                          remember no pictures didn't happen
                          Phil In Ohio
                          The basement woodworker
                          • jussi
                            • 2162
                            Just read this for the first time.
                            Omg Dud, I'm sorry to hear of your injuries, but that has to be one of the funniest stories I've ever read. The soda on my keyboard is evidence of that. Man, if you had a video camera rolling, you'd be $10,000 richer by now.
