Who is more at risk for injury in woodworking?
    Is it the newbie, who still has to learn proper safety techniques, or is it the senior woodworker who might be prone to become lax on safety?
    The newbie woodworker, who has a lot to learn
    33.33%
    37
    The seasoned woodworker, who might become lax in safety techniques
    66.67%
    74
  • gsmittle
    • 2793
    • St. Louis, MO, USA.
    I read somewhere (might be BTCentral) that usually experienced woodworkers are more prone to serious injury, because so many operations become routine and automatic. I know I've had to catch myself wanting to flick a small offcut away from a spinning table saw blade.
    g.
    Smit
    "Be excellent to each other."
    Bill & Ted
      I couldn't choose between the two. Failure to think ahead and follow proven safety protocols is dangerous, no matter how much experience one has, or does not have.
        This was a tough one, but I went with the "newbie" since things dine out of ignorance can have harsh results. I once needed to cross cut a bunch of parts the same size. I started to use the fence AND miter gauge until one of the old timers stopped me and explained what could happen. He then showed me the correct way to do it.
        Experience and the "it-can't-happen-to-me" is also bad JUJU!
        • footprintsinconc
          • 1759
          • Roseville (Sacramento), CA
          its hard to say.
          you have the cautious people, who think things out before trying them, then you have others, who just try first and think later (if they even bother ).
          so, to answer the question, both are at risk:
          • newbie: who may just attempt something without thinking it through or may attempt something and may think that the result should be safe when in fact, he could very well be just taking a chance that he doesnt know.
          • seasoned worker, who with time may have relaxed his safety conscious and could taking larger risks because he/she may think that they KNOW what they are doing.
          well that my answer.
          omar
            I voted newbie, with reservations. I've had some minor injuries that were mostly due to ignorance. But I also realize that experienced woodworkers (not claiming I'm experienced, either) can become complacent and take chances.
            Good to have these discussions though, to keep us thinking about such matters.
              • 4715
              I went with more experienced. I only say this, and yeah with a bunch of reservations, because I injured myself almost one year ago. I knew better than to do what I was doing. Woodworking is inherently dangerous even with only hand tools. Anything that can cut wood can cut flesh. All woodworkers should pay attention to the risks, eliminating those that they can, even sometimes modifying plans to avoid hazardous steps. Sometimes a hand tool is the safest way to work a piece. Even then without due caution it is easy for an injury to occur. I can not even begin to count how may times I've cut myself with a chisel.
              • Wandere
                • Dec 2007
                • 100
                • Madison, WI area
                Newbie...and it will probably be me, Murphy's Law. I'm well aware of my ignorance.
                Studies may have shown it's the experienced woodworker...I rarely trust a study.
                -Rob (911 on speeddial)
                • Carlos
                  • 1893
                  • Phoenix, AZ, USA.
                  I cut myself all the time, at least once per project, and I've been working with tools all my life. Never anything serious though.
                  • Wandere
                    • Dec 2007
                    • 100
                    • Madison, WI area
                    Here you go Carlos, spare antibiotics here: http://www.bt3central.com/showthread.php?t=35403
                      Rob,
                      Follow my signature. It's there for a reason.
                      • Wandere
                        • Dec 2007
                        • 100
                        • Madison, WI area
                        Thanks Ed, yours was one of the first articles I've saved into my "Saw 101" directory here. Great write-up (and handsome bench there too).
                        Thanks again
                        -Rob
                        • Russianwolf
                          • 3152
                          • Martinsburg, WV, USA.
                          • One of them there Toy saws
                          need a third catagory.
                          "woodworkers who purchase safety equipment thinking it means they can do anything"
                          Just like the people who think that buying a 4x4 with ABS and traction control makes them able to do 70mph on snowy/icey roads as per normal conditions.
                          safty tools are wonderful but can't replace good old common sense. If you get lulled in a certain carefree method because it works with your safety tool, what happens when you go to use your buddy's non-saftey tool the same way?
                          Lakota's Dad
                          • smorris
                            • Apr 2003
                            • 695
                            • Tampa, Florida, USA.
                            I don't know if it translates well, but, when I used to cave and climb we found as a rule that after 3-5 years you were more prone to have a serious accident. Almost every time it was because you did something you should have known better but you got lax in your safety because of past experience.
                            Newbies who had accidents usually had a minor one, they tended to be cautious and careful. (Minor defined as didn't require major medical to fix)
                            • dkerfoot
                              • 1094
                              • Holland, Michigan
                              I'd suggest it is whichever one removes the safety equipment such as the blade guard.
                              Doug Kerfoot
                              KeyLlama.com
