What would you do with it???
  • Thom2
    • 1786
    • Stevens, PA, USA.
    • Craftsman 22124
    I was helping clear out a warehouse awhile back and came across this:
    It was just too priceless to pass up, I mean, when would I EVER find ANOTHER one????
    It's apparently out of a locomotive (or Paul Bunyan's weed wacker????), and while I already have an idea of what I'm going to do with it, I thought I'd ask the creative bunch here and see what kind of ideas you guys might have.
    Thom
    inquisitive in PA
    • 2812
    Thom,
    Interesting, are you sure it's out of a locomotive? Looks like a smaller version of some of the power pistons I've seen in engine-process compressors. An "engine-process" compressor is basically a very large engine with the end cylinders acting as a compressor, to drive nat gas through a pipeline.
    Someday I'll figure out how to post pictures on here and perhaps then I can post some some examples. I've seen cylinders and pistons almost 36 inches in diameter and connecting rods that you couldn't put in the back of a pick-up.
    Your piston looks pretty clean (obviously either lost in shipment or was stocked in the warehouse, waiting for a repair to come up). You could polish it up and put a cut glass table top on it. It would make a nice conversation piece in the home bar!
    • bigstick509
      • 1227
      • Macomb, MI, USA.
      Cigar Ashtray
      It would make one great cigar ashtray.
      • Tom Miller
        • 2507
        • Twin Cities, MN
        Gosh, I guess I'd use it to drive screws.
        What's that big thing it's sittin' on?
        Regards,
        p.s. Even the rings from that thing would be impressive!
        • Stan
          • 966
          • Kalispell, MT, USA.
          • BT3100, Delta 36-717
          Ok, now that looks like a 'mail box stand' just waiting to happen.
          Or...
          A keg base?
          http://www.elksigndesigns.com
          • Jim Boyd
            • 1766
            • Montgomery, Texas, USA.
            • Delta Unisaw
            Looks like an chance to build a forge
            • Otter
              • 865
              • Cumming, GA, USA.
              • Delta Left Tilt UniSaw
              Chillie Roster, yep yep.......
              T.E. Lawrence
              • Popeye
                • 1848
                • Woodbine, Ga
                • Grizzly 1023SL
                I'm thinking a pedistal for a glass topped dining room table. Or coffee table. Which do you think Reva will let you get away with??? Pat
                • Bruce Cohen
                  • 2698
                  • Nanuet, NY, USA.
                  Hey Thom,
                  Your garage (shop) floor needs to be painted
                  Happy Fathers Day
                  Bruce
                  Samuel Colt did"
                  • just4funsies
                    • 843
                    • Florida.
                    Paperweight? Keychain?
                    (It may also have come from a marine engine. Seen some ENORMOUS ones.)
                    • WayneJ
                      • 785
                      (It may also have come from a marine engine. Seen some ENORMOUS ones.)[/QUOTE]
                      Maybe from an old LST or a tug boat.Might make a good bird bath.
                      Wayne
                      Wayne J
                        Hmm....
                        Yard Art.
                        Base for a tool.
                        Carpet it and it is a cat scratching post
                        Turn it over and use it to pack down dirt for patios
                          • 22085
                          Thom, looks like Aluminum, not cast iron.
                          I would think locomotives would benefit from weight (Gives the engines more traction) and not be made of aluminum.
                          Whereas airplane, and to a lessor extent boat motors, would benfit from lighter weight.
                          • dwolsten
                            • 122
                            • Chandler, AZ, USA.
                            I'm sure a locomotive has all the weight it needs from the chassis and the engine block(s). Higher reciprocating mass is always a bad thing in an engine: produces more vibration, reduces efficiency, etc. Why waste energy moving your pistons around when you can use that energy at the output shaft instead?
                              • 22085
                              Ah, good points, didn't think thru my comments, and wandering far from my field of knowledge.
