Computer Question
  • ndj
    • 75
    • Lexington, KY
    Computer Question
    I can follow directions very well and have been able to teach myself how to perform the functions that I need to do on computers. But, I've never been able to take the time to learn how to get into the technical aspects of operating systems, java, etc. I use a laptop mostly that was configured by an IT dept. My desktop, however, was ordered direct and aside from the manufacturer's setup and default settings, it's pretty much been left alone.
    Problem I'm trying to resolve:
    On my laptop, web content seems to almost always download without any gliches. On my desktop, however, it's very common to go to a website and much of the graphic content on the page doesn't download.
    All I get is the box where the graphic should go with a small red x on the corner. I'm sure everyone has seen this at one time or another. After this long winded description, my question is: What do I likely have to do to change the settings to allow these graphics to download?
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    I am sure You will get some help on this, but it's probably a check mark left out or turned on when it should be off. Bill
    • ndj
      • 75
      • Lexington, KY
      Thanks DUD. I have gone through all of the tabs in "Internet Options" but really have no clue what it would be. There are alot of computer experts on this board so I agree with you. Plus its probably something extremely simple and I've overlooked it.
      • DonHo
        • 1098
        • Shawnee, OK, USA.
        I'm not a computer expert either but I think you might need to download what ever software the "red x" requires to play on your computer. Usually you would get a message that ask if you want to download. The software is usually free but of course you should be careful that you only download from a "safe" well known company.
        DonHo
        Don
          • 22109
          If you run your cursor over the red X (and maybe you need to right click on it) you should be able to see the object properties, what you want to know is the file name and type. If the type is GIF or JPG then you are not displaying most graphics and probably have the display graphics checkbox off in your browser, this is rarely set off since the advent of high speed lines, but i suppose it could be checked.
          If the objects that are "X"ed are other types then usually you need some plug ins for your browser or to have them associated with viewers or players. Again this is a little confusing because usually when you don't have a player one will be offered to you to download and install unless you have really strong security set which prevents popups or even prohbits the loading of the object files.
          • mschrank
            • Oct 2004
            • 1130
            • Hood River, OR, USA.
            Do you ever see graphics/pictures? If not, check under Tools-Internet Options-Advanced Tab (assuming you're using Internet Explorer) . Scroll down to the "Multimedia" section. Make sure the box next to "Show Pictures" is checked.
            • ndj
              • 75
              • Lexington, KY
              Thanks for your suggestions. I'll trt to provide a little more clarity to what I'm trying to solve since, I doubt that I'm using the correct terminology for the issue. This webpage for example, I can see all of the graphic objects with the exception of the Rockler banner at the top of the page. A couple days ago KomaToast posted a link to a streaming video sight showing an eagle's nest. I couldn't see the video, just the box where the video would be. However, on my laptop, I could see it with no problem. Hopefully, this provides a little better discription of what I want to solve. Thanks again.
                OK, need to start with some basic questions. Is this YOUR computer (you own, at home) or is this a work computer?
                If this is a work computer, do you have administrator rights?
                Some of this sounds like you are missing a flash plugin, while other parts sound like things have either intentionally been disabled, or you are going through a proxy at work.
                There are reasons the stuff could be disabled.
                • ndj
                  • 75
                  • Lexington, KY
                  LinuxRandall
                  Thanks for your reply. Both my desktop and my laptop are personal computers. I just ordered the desktop direct from HP and the laptop I purchased through a reseller who simply preloaded all of the software and configured everything.
                  • DaveW
                    • 415
                    • So Cal.
                    The Rockler banner is just a GIF file - so if you can't see that, and if your images settings is on (per others' suggestions), the thing I'd suspect isn't a flash plug-in etc - I'd question if maybe your computer's DNS settings etc aren't looking up those hosts properly. i.e., your computer is allowing images from bt3central.com to come through, but not from rockler.com etc. Or maybe you have some firewall software that's blocking the same kind of thing?
                    • RayintheUK
                      • 1792
                      Sounds like a pop-up blocker is working if you cant see an advert graphic. Excuse poor punctuation - foreign (Italian) keyboard! If thats all it is, dont worry about it.
                      Ray (in Rome)
                      Did I offend you? Click here.
                        Are you using Norton Internet Security?
                          LinuxRandall
                          Preconfigured, I am guessing service pack 2 with the firewall active, and set to disable items (like the gif). Check your bar, lower right screen, and see if one of the icons shows Windows firewall. Best bet if it is active, would be to google it for settings, and experiment with different ones and sites you normally go to. My mothers pc has problems with ONE site, that the grandkids use, only the one, so the setting need to be adjusted by the grandkids everytime, as mom isn't computer literate.
                          Check the laptop for the firewall to, then compare settings.
                          • ndj
                            • 75
                            • Lexington, KY
                            I suspect that it's related to the Norton Anti-Virus. It seems to be the culprit in so many other things. I use the Norton firewall and have disabled the Windows firewall. I just don't know how to override whatever settings that Norton may have changed to fix the problem.
                            It's really not a serious problem. It's just that sometimes, it blocks out graphics that would be useful to see.
                              I had stuff like that happen with Norton Firewall and AV. I got rid of all the Norton software and got back all the system resources it was eating. I went with AVG Free for awhile, then AVG Retail. AVG is nice to your system. Now I use Windows Onecare with AV, Firewall and Spyware detection, and IMO, it's the best I've ever used.
