Rip Fence Repair Help
  • NickAllen
    Handtools only
    • Feb 2015
    • 1
    I recently purchased a new roller holder, p/n: 969154002, as the original piece was falling apart. I am having trouble removing the Clamper B Roll pin p/n: 941401309 from the Clamper. Before I take my BFH or a grinder to it, does anyone have a suggestion or trick for removing the roll pin?
    • 4715
    Support the end of the fence and use a roll pin punch to drift it out.
      • 1865
      Mark,
      On the off chance I have to do this one day, and don't have a roll pin punch handy - could one of the HF transfer punches from this set be used instead? Or even a thin nail set, like the one from this set?
        • 3570
        I wouldn't use the transfer punches, it will mess them up badly. They are too valuable for other purposes to have messed them up doing this! I'd mess up a Philips screw driver first!
        capncarl
          Internet Fact Checker
          • 20989
          you can drive it out with any flat faced cylindrical item that is smaller in diameter than the pin. Like a small diameter long bolt would work. Transfer punch is a bad idea as you don't want to expand the end of the roll pin by punching it with a pointed tool. probably won't hurt the transfer punch since its made to punch metal.
          When you re-install it use a press... a clamp with a slow even closure (C-clamp, or quick grip clamp) that you screw or squeeze gently can be used for this.
          Lineup and pin punches can be good for this. If you don't have a set it might be a good time/excuse to get one. Part of the right tool for the right job program.
          $12 at Sears, lifetime warranty.
            • 4715
            Mark,
            Yes Bill a person could use a transfer punch to do this. A nail set would not work. A flat faced punch is the way to go. Roll pin punches make it easier because of the raised locating protrusion on their face which keeps the punch centered over the pin. This is one of those times where the correct tool for the job and right set up make a world of difference.
              Just me
              • 8441
              I am very surprised that you are having trouble with that. It has been about 6 - 7 years or so since I had to replace the end on mine, twice within about a year. The roller pin section was not damaged, but even then, the pin just pushed out and back in with such ease, I wondered why the pin would even stay in. I never had a problem with it coming out but it wasn't a tight fit for mine.
              • Kem
                Handtools only
                • Jul 2015
                • 4
                Greetings:
                New user to the forum and the BT3000, just picked one up last week that had a broken Roller Holder on the rip fence, had a heck of a time getting that roller pin out, had to get a bigger hammer and that worked. But the rip fence is repaired and working, just need to replace the missing blade guard assy. and I will be ready to go!
