"Copy" and "Past" Triangles
  • niki
    • 566
    • Poland
    • EB PK255
    Good day
    Tom Finnie presented the idea to me after he saw the "45° frame cutting sled".
    But I took the pictures myself…
    I leave it to your imagination what you can do with it.
    Regards
    niki
  • niki
    • 566
    • Poland
    • EB PK255
    • niki
      • 566
      • Poland
      • EB PK255
      • niki
        • 566
        • Poland
        • EB PK255
          • 22108
          great idea (who ever it was), and your illustrations, as usual, are nice and easy to follow.
          If you use it for a triangle, you might take a 1-1/2 to 2" forstner and drill a hole in the middle to make it easier to handle and slide around and give you a way to hang it. If you want put a triangular hole but that's more work. Bevelling the opening will make it easy to pick it up.
          I think those are the reasons why most commercial drafting triangles have the triangular opening, I think a circle will do, though.
          • jAngiel
            • Oct 2003
            • 561
            Thanks. I have been contemplating a way to make triangles similar to that to use for putting cabinets and shelves together. I plan on cutting some flat spots so I can use it with clamps, similar to Rocklers "Clamp It".
            I also plan to use it for making a crosscut sled, I have been wanting to build one of those for a long time.
            James
            • niki
              • 566
              • Poland
              • EB PK255
              LCHIEN
              For the time being I installed one on the 45° crosscut sled so I did not need any hole, I did not decide yet what to do with the others but your idea is very good.
              James
              Interestingly, I was thinking the same, but in this case I think it will be better to "copy" it to 1/2" or 3/4" plywood so it will be more rigid.
              Thanks
              niki
              • Wood_workur
                • 1914
                • Ohio
                • Ryobi bt3100-1
                that is a good idea.
                Alex
