"Compact" Lumber Cart
    After months of skirting a pile of cuttoffs and stock leaning against the wall, I decided I need to organize it, but don't have alot of room for any large storage in my garage-shop. Saw an appealing design in Shop Notes, #99, for a mobile lumber cart that also incorporate a sheet cutting "system" for those times when you need to cut down sheet stock.
    Instead of using the birch ply shown in the SN article, I took the economy route, and used OSB (consumes 3 sheets). Pretty much followed their plans for the rest, except minor design "improvements" here and there.
    This thing turned out a lot beefier than I expected - and larger. There's a small sheet storage area in the front (I added the lower bin area for long cutoffs), upper shelving, and a larger sheet bin area in the back; the rails for the sheet cutting "system" have a lag-screw near each end that hook onto the slotted aluminum rests fastened to the sides.
    Materials, all told, ran about $70. Assembled as shown in plans as butt joints with plenty of glue, but instead of screws, used my HF framing nailer - tricky, but worked OK.
    Thanks for looking.
    Interesting design. Going to have to see if I have the issue.
      I think I've seen a similar design, Bill. It's a nice one and very functional. I could use about 3 of them "right now" as I am waiting on a new TS to replace the Uni-saw going out the door in about 30 minutes. But.. either way I have to do something with the scrap that has accumulated in just 9 short months building a bedroorm suit.
      Nice indeed....
        Thanks guys. Functional is key for me - is obviously not a thing of beauty that took alot of time and attention to detail!
        I'm going to increase functionality by adding a clamp-rack to the back of it - all those clamps in the bottom left of this picture, and some not shown, need a home, and all that empty space on the back should work out well, I believe.
          In this case, I'd take function over beauty any day.
          • jhart
            • 1715
            Good idea about the clamp rack on the back. Rest looks very functional and easy to store all the extra's.
              Function can be a thing of beauty in itself. I personally like the looks of the old WWII Jeeps for example, and those things were never designed to be beautiful...
              The OSB is an interesting idea. I am curious how that is going to hold up in the long run...
              I like your idea of multifunction with the clamp rack etc... there. Make your clamp rack with more capacity than you need! If your shop is anything like mine, clamps just seem to jump into your cart every time you walk into HF for some odd reason...
                Finally added the Clamp Rack
                I stayed with the "simple" concept of the overall cart. I just cut dadoes in a piece of 2x3 and mounted it to the back of the cart. Appears that it will work fine.
                Thanks for looking.
                • footprintsinconc
                  • 1759
                  • Roseville (Sacramento), CA
                  cool idea. good use of space. doesnt take any extra space.
                  omar
                  • StickSeler
                    • 54
                    • Alexandria, Virginia, USA.
                    Looks good, how thick is the OSB?
                    Of course Lumber is expensive,what do you think, it grows on trees
                    http://www.rjkniatt.com
                      StickSeler,
                      The OSB is 3/4in. IIRC, it was the most affordable material from the BORG at my immediate disposal, at ~$14 a sheet. Took 3 sheets, with very little scrap.
                      • StickSeler
                        • 54
                        Thanks Bill
