Turning Infested Birch
  • JoeyGee
    • 1509
    • Sylvania, OH, USA.
    So, I have discovered our paper birch tree is infested with a borer. Half the tree is dead and the other half is showing signs of infestation. I am going to cut the whole thing down.
    Can I do anything with the wood or is is best to just burn it all? I would love to save some for bowl blanks and other smaller projects.
    • 3126
    I guess it depends on the type of infestation. If the pest is one that can survive in the wood after the tree is felled, I would recommend burning it. If you can find way to be certain you can kill the pest while keeping bowl blanks, I don't see a problem. To me the most important consideration would be whether or not you are going to facilitate the spread of a pest.
      As twistol say it really depends on how bad it is and how much decent wood you think you will recover from it. Do you know exactly what the infestation is? I had something eating into the large walnut slabs I used to make the table I posted recently. After much research I ended up using some Timbor to treat the wood.I had previously used a general termite spray to get the basic stuff killed. As it happens once fully treated and I started cleaning out some of the debris I found 2 rather large Carpenter Bees in there. They make rather large holes!
      Assuming you do decide to keep the logs I would put them somewhere in the yard away from any of you other stored wood while you treat the infestation. Then cut to reasonable sized blanks to dry and season. that way you can be reasonably sure you git all the little buggers!
      I got the Timbor from Amazon.
      https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
        Joey,
        Jon's suggestion of Timbor is good. An additional method is to create a kiln of sorts and sufficiently heat the wood to kill the bugs. Check out this video: https://www.youtube.com/watch?v=qpE7JNnHIRo
          Joey,
          Interesting video Bill. His little makeshift kiln was averaging 140 degrees with the heater. Here in Phoenix yesterday we topped out near 120! I bet if I made some form of metal enclosure and left it out in the sun it would go way higher then 140!
            Great idea Jon - lexan might work too (like a green house) - would be interesting to try a scale model and check the temps. (120! - I don't know how you do it.)
