HF lathe chisels
I have the $50 HSS HF set item#69723 .. Out of the box they are OK but they will take a nice edge..
Withe the fatory edge and my ham fisted attempts on the grinder I had problems with lots of tear out when turning cherry.
I sharpened the skew with a Lansky kit I have for the the kitchen knives. It got the skew sharp enough to cleanly slice a sheet of paper end to end and turn cherry to an amazing smooth finish that almost glows.
That edge held up through about 12 blanks ( a mix of acrylics, purple heart and desert Iron wood) before it needed a touch up. It was back to throwing nice little curls with just a few swipes on the stone to dress it up.
90% of the time I just use the large skew, either roughing gouge and the parting tool for pen work.William's Law--
cannot be solved by brute strength and ignorance.Comment
Christmas brought a set of the Bodgers, which was a nice surprise. Can't wait to test drive them and make a comparison.Comment
i finally got that same set, and i noticed that, they didnt come with a nice edge. i guess i have to do a little bit of sharpening before. I can't wait to start playing, but my shop is in the basement with no heat, and with the temperature outside in the low 20, it's a little bit unpleasant to work there
I bought a little personal heater about this time last year for $5. I upgraded a couple of weeks ago to the Craftsman garage heater and it does quite a nice job for $40. I bet with your basement you have better insulation than my standalone shop, it might work well for you.i finally got that same set, and i noticed that, they didnt come with a nice edge. i guess i have to do a little bit of sharpening before. I can't wait to start playing, but my shop is in the basement with no heat, and with the temperature outside in the low 20, it's a little bit unpleasant to work there
http://www.sears.com/craftsman-ceram...p-03290285000P
It's the only way I'm going to be able to be in my shop for about the next six weeks or so.Comment
My basement is unfinished, concrete floor and no insulation at all, and to make things worse we have water problems, if it rains a lot it gets wet.I bought a little personal heater about this time last year for $5. I upgraded a couple of weeks ago to the Craftsman garage heater and it does quite a nice job for $40. I bet with your basement you have better insulation than my standalone shop, it might work well for you.
I've been using a ceramic heater, but when it's below 30 is imposible to take the chill off with a small heater, i think my best bet would be a propane heater, or better yet, move to a house with a nice shed with a woodstove
daydreaming...Comment
I sharpened my skew sitting at the dining room table in a nice warm room.
As long as I don't do anything dumb like melt her new table cloth (again!) she is very forgiving of my sneaking shop work up into the living space. If it does not stink, make much noise or damage the table I can generally get away with it.Last edited by sscherin; 12-27-2013, 04:02 AM.William's Law--
