Casting in black epoxy?
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    Hi All,
    I have a project in mind where I would cast items into black epoxy and turn the result. There would be quite large gaps (approximately 50% would be epoxy), and I'd like the epoxy to be black.
    I have not much experience with epoxy beyond 5 minute epoxy for glueing.
    What type of epoxy can you recommend that is not too expensive, and can be cut and polished to a high gloss? How can the epoxy be colored to be deep black? Or should I look at other materials, and if so what would those be?
    Thanks
    Gerd
    i have no turning experience but I have perused this website before for casting ideas http://www.smooth-on.com/Urethane-Pl.../c5/index.html
    hth
    • BigguyZ
      • Jul 2006
      • 1818
      • Minneapolis, MN
      Penturners.org has a LOT on casting.
      But in general, I've used testors to color epoxy with good results. Just don't go overboard with the testors- a little dab will do you.
      I think Woodcraft also carries a product specifically for that as well.
        your biggest problems in casting epoxy are:
        1. mixing the epoxy and then getting the bubbles out. Turning it will show tiny bubble voids so you need to evacuate it after casting to boil off the bubbles. Like a bell jar and a vacuum pump. A low viscosity mix helps avoiding entraining bubbles.
        2. having the epoxy flow all around the item and leaving no voids - requires an item that can be poiured with no concave surfaces facing down that will trap bubbles
        3. selecting the right epoxy - slow set up you'll have to wait a long time, fast setup you will get heat damage, shrinkage and capture of bubbles before letting them get out.
        I've not cast items in black for machining/turning but I've cast items in clear that required through visibility after curing.
          Michaels and Hobby Lobby both have casting resins and tints for them. In general, these work better than epoxys with colors added.
          Also, there are different kinds of resins so a little research will help. Some resins set in 5 minutes; some set in hours.
          • gerti
            • 2233
            Thanks everybody for the tips! I found this stuff which looks promising:
            http://www.smooth-on.com/Urethane-Pl...325/index.html
            It'll be a while before I get to this, but when I do I'll let you know what I ended up using and how it went.
            Gerd
