Lathe questions
  • Workman
    • 70
    Lathe questions
    I have the opportunity to pick up an old Blount lathe for the price of carrying it away (free). I think this thing weighs about 600 pounds and is complete, but is a three phase machine. Appears to be about a 12" X 40" bed. It all seems to be in good (although old) shape - everything is there. I don't know if it runs/no way to presently hook it up. What do you think? Is this worth pursuing? Do any of you have experience with rebuilds/conversions/etc?
  • Daryl
    • 831
    I am not a turner, but I found this on the web:
    " THE JOY OF WOODTURNING IS DIRECTLY PROPORTIONAL TO THE MASS OF YOUR LATHE"
    I suggest you grab it and look for a phase converter.
      ... or a single-phase motor that will fit...
      • final_t
        • 1626
        For the free price I'd go and grab it just as a refurb project. You can pick up a good motor elsewhere.
        And if it's in Cowtown Ohio and you don't want it, I know someone who would!
        • eezlock
          • 997
          • Charlotte,N.C.
          lathe questions
          From what you have described so far...it sounds as if that is a metal working lathe...not a woodworking lathe. I would want to see it run before taking on a project like that...being three phase powered and all. It might get to be very expensive buying a different motor to run it on home /shop single phase power (which is what your house normally has) or buying a phase converter
          probably $800- $900 for that! Might want to give it a strong second look before jumping on that deal...even if it is a freebie! eezlock
          • just started
            • Mar 2008
            • 642
            • suburban Philly
            See this link for a possible source of info
            http://www.owwm.com/mfgindex/detail.aspx?id=109&tab=4
            and some pix.
            • garymuto
              • Aug 2007
              • 194
              • Encinitas, CA
              • Delta Cabinet Saw
              What makes you say that it is likely a metal lathe??
              • Thom2
                • 1786
                • Stevens, PA, USA.
                • Craftsman 22124
                Personally, and this is just me ... but I'd be ALL OVER THAT. Even if it was single phase I would most likely swap out to 3 phase anyway since a VFD (Variable Frequency Drive) requires a 3 phase motor.
                Since this unit is already 3 phase, adding a variable frequency drive would most likely be much cheaper than replacing the motor with a quality single phase unit. You will need 220v to run the VFD, but IMO it'd be well worth considering since the VFD will give you infinately adjustable variable speed. Also, VFD's are available with reverse.
                I haven't slid down the slippery slope of a lathe yet, but a deal like this (if in good shape and suitable) would be exactly what I was looking for as I already have the VFD's laying around.
                Just my thoughts ...
                • eezlock
                  • 997
                  • Charlotte,N.C.
                  Lathe questions
                  The reason for saying what I did about it being a metal lathe was based on past information. At one point in time, I had a chance to be around different types of machinery....in industrial settings,and one of those shops had a
                  Blount lathe. That is not to say that Blount did not make woodworking equipment, but is/was better known for their metal working machines.
                  Just like saying something like "Southbend" what do you think of first?
                  Me, I always think of Southbend as nothing but lathes...they may have made other machines...I don't know, but their lathes were very popular
                  in a lot of machine shops! eezlock
                    • 22106
                    just stole a look at EBay, VFDs, a bunch are available for 1 ph to 3 ph, 230V in 1 to 2 HP out. Looks like in the range of $120 for the 1 HP to $200-250 for the 2 HP.
                    does the "beast" have more than a 2 HP motor?
                    have to sort thru the volunteer fire dept stuff and the Vacuum flourescent-tube displays.
                    • Thom2
                      • 1786
                      • Stevens, PA, USA.
                      • Craftsman 22124
                      http://web1.automationdirect.com/adc...FQfNIgodAGYjDQ
                      Brand New 1hp GS1 unit .. $125
                      2hp GS2 unit ... $235
                      3hp GS2 unit ... $289
                      • Workman
                        • 70
                        Your helpful information has been greatly appreciated. We'll see if I wind up with this lathe, and if I'm able to do the necessary work to make it work the way I want. There is no question that this is a wood working lathe. I'll let you know how it all turns out.
                        • Workman
                          • 70
                          I did get the lathe (rescued from the truck on the way to the scrap bin), cleaned it up a bit, installed a new Hitachi VFD (complicated by the fact that this is a consequent pole motor head lathe with a four speed drum switch with no wiring diagram), and it is the smoothest running lathe I have ever seen. Many thanks to all for your advice and help.
                          • Thom2
                            • 1786
                            • Stevens, PA, USA.
                            • Craftsman 22124
                            Pics???
                            daggummit ... we expect pics 'round here
                            • shoottx
                              • May 2008
                              • 1240
                              • Plano, Texas
                              Old wood working machines site
                              http://www.owwm.com/home.aspx
                              I found an operating instructions and a parts manual for an old Sears Shaper I am restoring on this site. It is full of great information
                              For more information on sources and a key to abbreviations used in the Manufacturers Index, see: Sources of Information. If you have information to add to this Manufacturers Index entry, please contact the Old Wood Working Machines Historian.
                              This company, founded in 1888, made woodturning lathes, grinders, and polishers. At some point they were bought out by Williams & Hussey Machine Co., Inc., but that company no longer supports Blount products.
                              This lesser-known maker receives uniformly high praise for their lathes. The U.S. military bought quite a few of them, judging by the number of ex-navy lathes on the used market.
                              Information Sources
                              1909 catalog of "grinding, polishing machinery, and speed lathes." The catalog says that the company was established in 1888. "Speed" brand and "Stuyvesant" brand. The catalog shows lathes with swing of 11", 13", or 16", with beds from 3' to 12' long.
                              12"/17"x40" gapbed lathe from 1955 (there were no gapbed lathes in 1909 catalog).
                              We have seen a lathe labeled, "Manufactured by J. G. Blount Co. / A division of Williams & Hussey Machine Corp. / Milford, New Hampshire 03055".
