won't be turning for a while
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    was working on a spindle in the shop last night when it happened.
    Catch....Bang.
    broke the tool rest right at the joint where the rest meets the post. I'm now out of commission until I can get a replacement.
    Lakota's Dad
    Weld shop?
    • Russianwolf
      • 3152
      PSI is out of stock of their 3 piece set.
      I don't like the looks of the welded ones.
      Someone recommended getting a piece of bar stock the same diameter as the post and having a 90 degree bend put in it. He turns bowls on one (although heftier than my 5/8th inch I'm sure) that are larger than the tires on my jeep. http://www.koawoodhawaii.com/3.html (first pic in the fifth row). I like the idea as I can have a 9 inch bar bent so that I could use it either way as a 6 inch or 3 inch (excluding the bend)
      Lakota's Dad
      • TB Roye
        • 2969
        • Sacramento, CA, USA.
        Turning something that big is absolutely scary. Wonder what the speed is on the Lathe and how big is the Lathe. Wonder what the tools look like.
        • Russianwolf
          • 3152
          Assuming that the blank is 36 inches in diameter (the 56 inch max is too scary to think about) the RPM would be multiplied by 113 compared to a 1 inch diameter spindle. So 200 rpm for 1 inch would be 2200 inches per minute on that outside edge.....
          :whoa:
          Lakota's Dad
          • guycox
            • 360
            • Romulak, VA, USA.
            :whoa:
            I can turn in turn a piece in excess of 54" on the 'Frankenstein" lathe -- I haven't found a decent piece of wood that large or an extension cord long enought so that I can get the house and the shop out of the "line of fire" if something goes arwy.
            Scarier than snapping a toolrest is snapping a headstock shaft
            Guy Cox
            Life isn\'t like a box of chocolates...it\'s more like a jar of jalapenos.
            What you do today, might burn your butt tomorrow.
