Grizzly BS blade tensioner on a HF BS
  • jonmulzer
    • Dec 2007
    • 946
    • Indianapolis, IN
    #46
    I just ordered all the parts from Grizzly's website. I hope it gets here soon. I notice a few people have mentioned that Grizzly bandsaws take a strong arm to throw the tensioning lever. For those that have done the mod, what did you think? If necessary I can use the lever that I ordered as a template to make a longer one with more leverage I suppose.
      • 4715
      Pat's gallery link is now fixed! You are welcome.
      • jonmulzer
        • Dec 2007
        • 946
        • Indianapolis, IN
        #48
        I received my parts today. Apparently #33 does not include 130A&B nor 131A&B so now I have to order those parts also. I am going to the basement first to make sure everything else fits as it should before I order the rest of what I need.
        Does anyone know if a Grizzly upper bandsaw wheel is interchangeable with a JET? Since mine has a wobble and I am ordering parts from Grizzly for this it would be great if it worked out. Doubt it will though.......
          • 9233
          Whatever this means but an earlier post has this to say...
          1) Since Pat measured the center to center dimension of the support plates (4-5/16") doesn't it look like all we really need to order from Grizzly are items - 131 FixedLump (used to be 131a/131b - see new Grizzly parts list it has been revised), 133 LeverRod, and 141 FixedBase? The rest look like they can easily be shop made or store bought.
          • jonmulzer
            • Dec 2007
            • 946
            • Indianapolis, IN
            #50
            The parts list has not been revised though. You still have to order all of that separate. Oh well, I was wanting to order some paddle switches from them and forgot about it the other night. Looks like I get a second chance eh?
              • 9233
              Well, if you'd like, you can order an extra set of those parts and have them shipped to me!
              • jonmulzer
                • Dec 2007
                • 946
                • Indianapolis, IN
                #52
                While I appreciate the offer, I think I can manage. :P
                  • 9233
                  How much does this entire mod cost anyway?
                  • jonmulzer
                    • Dec 2007
                    • 946
                    • Indianapolis, IN
                    #54
                    Roughly $50. You can total it all up on Grizzly's website.
                      • 9233
                      Finally pulling the trigger on this one. Just ordered the parts. $31.20 after S&H to my door...
                      Will post project pics and write up when done.
                      • jonmulzer
                        • Dec 2007
                        • 946
                        • Indianapolis, IN
                        #56
                        Did you order the additional parts that go with the tension adjuster rod?
                          • 9233
                          I ordered the following parts...
                          33 P0555033A 1 Blade Adj. Screw Assy 7"
                          133 P0555133 1 Lever Rod
                          135 P0555135 1 Bushing
                          137 P0555137 1 Bracket
                          140 P0555140 2 Support Plate
                          141 P0555141 1 Fixed Base
                          According to the tech I talked to on the phone, that is all of the pieces / parts aside from the screws and washers...
                          • jonmulzer
                            • Dec 2007
                            • 946
                            • Indianapolis, IN
                            #58
                            Hopefully your tension rod comes with the rest of the pieces. Mine did not so I also had to order 130 a&b and 131 a&b. Somehow I seem to have misplaced those four pieces also, so until they turn up I am waiting to install this.
                              • 9233
                              From all the above posts talking about the merged part #, where the parts you mention got merged into the Part #P0555033A Blade Adj. Screw Assy 7", I verified this with the Grizzly rep on the phone. So either they parts come in, or I have to order a couple of additional components. But I doubt it. We will just have to wait and see...
                              • jonmulzer
                                • Dec 2007
                                • 946
                                • Indianapolis, IN
                                #60
                                (1) P0555137 BRACKET
                                (2) P0555140 SUPPORT PLATE
                                (1) P0555133 LEVER ROD
                                (1) P0555135 BUSHING
                                (1) P0555141 FIXED BASE
                                (1) P0555033A BLADE ADJ SCR ASSY 7" THREAD
                                I think that is the same as your order. I have not compared the minutiae of the numbers, but at a glance I think they are the same?
