Grizzly BS blade tensioner on a HF BS
  • Stan
    • 966
    • Kalispell, MT, USA.
    • BT3100, Delta 36-717
    I called 1-800-523-4777 to order the parts.
    One note, you'll notice that parts 130 A&B and 131 A&B are missing from the list of items ordered. Apparently those items are included with Part # 33 now (they may mention that there is a new part number for that item -- did when I was talking to them anyways).
    Good luck.
    http://www.elksigndesigns.com
    • Popeye
      • 1848
      • Woodbine, Ga
      • Grizzly 1023SL
      Thankyou Mr. Foy Teamwork is what this place is all about.[^]
      Just a note, can't remember if I mentioned it in the original post. I used 5/16"-18 mounting bolts because I had that tap already. You could use the 8mm 1.25 if you have the tap.
      Although I used the metric bolts item 138 5/16"-18 would work fine there too. I wasn't sure at the time if it would make a difference in the fit going throught the fixed base (141) and bracket (137) it won't.
      Best and easiest tool enhancement I've done in awhile. Pat
      • tfischer
        • 2343
        Uh oh. Tap? Is there retooling involved?
        I don't have any taps/dies currently, and buying a set, even from HF, would probably price this mod out of my range right now...
        -Tim
        • Stan
          • 966
          You could save some bucks and just buy the size tap you need for now rather than a whole set. True Value store here carries a set with a matching drill bit and tap in one package for around $4.00.
          You 'can' turn the tap with a wrench, but as discussed with Pat just a bit ago in the chat room (and I agree), having a tap handle would be better.
          • tfischer
            • 2343
            Just to clarify, can someone please step me through how to do the mod? I had assumed I just had to replace some HF parts with Grizzly ones, but now we have a tap involved... [:0]
            -Tim
            • Stan
              • 966
              -Tim
              Take a look at the link that Pat provided on the first message in this thread. He took a series of pictures that show the three holes that need to be drilled/tapped on the bandsaw.
              • tfischer
                • 2343
                [quote]quote:Originally posted by Stan
                Jeez I totally missed that link -- thanks!
                -Tim
                • Popeye
                  • 1848
                  • Woodbine, Ga
                  • Grizzly 1023SL
                  #23
                  -Tim
                  http://bt3gallery.fhauto.com/view_al...umName=album53 pretty basic picture show, but I hope this helps. See ya'll Friday nite. Pat
                  • tfischer
                    • 2343
                    I think I spoke too soon -- just notice this: http://www.harborfreight.com/cpi/cta...emnumber=39391 for $9.99.
                    I was under the impression a tap/die set started around $40...
                    Is this all I really need in addition to the above parts list?
                    -Tim
                    • Popeye
                      • 1848
                      • Woodbine, Ga
                      • Grizzly 1023SL
                      #25
                      Yep, that's it. Pat
                      -Tim
                      • tfischer
                        • 2343
                        Finally got around to ordering this stuff... Everything's in stock except the bushing, 4-6 week outlook for that!
                        Any chance I could use something else for a bushing? If not I guess I'll be waiting for it (I ordered it, anyway...)
                        Thanks again for a great, affordable mod!
                        -Tim
                        • Bollox
                          • 113
                          • Indianapolis, IN, USA.
                          #27
                          -Tim
                          Tim,
                          Grizzly told me the same thing last week, so I spun up a bushing Friday night at work. Wouldnt you know it, the Grizzly part arrived today (Monday). Let me know if yours doesnt arrive soon and I'll send you my Grizzly one.
                          Popeye,
                          What I couldnt get right now was the 2 spacers on the threaded rod (p/n 131 A & B) any chance you could measure yours and give me a length and diameter?
                          Thanks for posting this mod. Remembering to wind off the tension every night is not something I'm good at!
                          • tfischer
                            • 2343
                            [quote]quote:Originally posted by Bollox
                            Uh oh, I didn't even try to order those -- according to the parts list above they came with one of rod itself? Guess I'll see what I end up with.
                            Thanks for the offer of the bushing -- I'll see what happens! I still have to pick up a tap set too, plus all the related hardware that I didn't order through Grizzley...
                            -Tim
                              Internet Fact Checker
                              • 20997
                              Yep, that's it. Pat
                              -Tim
                              that looks dangerously inexpensive.
                              My last set of HF taps/dies you could see the twist build up in the tap as I turned it, it was so "soft".
                              And my set was $40 I think.
                              You'd probably do better getting a single size tap and properly sized drill bit as was suggested earlier.
                              The really cheap sets at HF I'd only recommend for chasing existing threads and holes that maybe got fouled or bunged. They also don't include the numbered-size bits you need to do properly. The fractional sets most people have aren't a fine enough selection.
                              Carbon steel is also the bottom, bottom end of the chain. Next better is HSS or I guess they call alloy steel.
                              • Popeye
                                • 1848
                                • Woodbine, Ga
                                • Grizzly 1023SL
                                #30
                                -Tim
                                Tim,
                                Popeye,
                                Sorry Mike and Tim,
                                My tensioner came with the two "fixed spacers" attached. I had initially ordered them and was told they were backordered too. Then the rod came in with them on it so I cancelled the backordered parts.
                                Mike, the upper spacer measures 1.339" dia X 1".... the lower is .750" X .750". Hard to get anything like a precision measuring instrument in there now.
                                "Both have set screws" so if your have to order them those need to be ordered too. Part no #'s PSS05m and PSS07m
                                Mike I'd have thought you'd be too busy to mess with bandsaw parts this time of year. I'll be watching Sunday. Which team do you work for? Haven't been to a 500 since 78 but I'll be home for the Brickyard in August. No offense[B)] Pat
