I compiled a cross reference list of Delta tools to their Shopmaster Equivalents.
    I bought a number of power tools from Delta prior to and around when they made the change. I find it helpful to know which models are equivalent to help in finding the same design under two model numbers to help interchanging/compatible parts. Maybe this cross reference list will help someone else. I actually own 6 of these tools on this list.
    Delta Shopmaster Model no. Crossreference
    Loring Chien 2026
    Between 2000 and 2003 Delta was acquired by Pentair and rebranded their entry level Hobbyist benchtop and floor tools to Shopmaster and changed the Delta nn-nnn model numbers to AAnnn Shopmaster model numbers while keeping the design pretty much the same except for new labeling. I with the help of AI have assembled a before and after model number list. This is important because many of these tools are now discontinued and the parts list of the before and after models are identical , helping searchers find identical models from which to scavenge parts. Because these tools are essentially the same, you can often find compatible replacement parts (like brushes, belts, or blades) listed for both model numbers. For instance, parts for the 22-540 are almost always interchangeable with the Shopmaster TP300. Or scavenging a broken 22-540 could fix your TP300.
    Tool Type Original Delta Model Shopmaster Rebrand
    12" Portable Planer 22-540 TP300
    12.5" Portable Planer 22-560 / 22-565 TP305 /
    TP400LS
    1" Belt / 8" Disc Sander 31-340 SA180
    10" Benchtop Table Saw 36-600 TS300
    10" Compound Miter Saw 36-075 MS250
    6" Benchtop Jointer 37-070 JT160
    12" Benchtop Bandsaw 28-190 BS220LS
    9" Benchtop Bandsaw 28-150 BS100
    Air Cleaner 50-860 (partial equiv.) AP100 Triangle design with integrated work lights; 450 CFM.
    Air Cleaner 50-860 / 50-868 AP200 Standard rectangular ambient air filter; 850 CFM.
    Filter Part Numbers
    If you are looking for replacement filters, the following numbers are interchangeable for these units:
    • Inner Filter (1-Micron): Part 50-859. This 3-pocket inner filter fits the
    Shopmaster AP200, as well as the Delta 50-860, 50-868, and 50-875
    professional models.
    • Outer Pre-Filter (5-Micron): Part 50-858. This fits the AP200
    and the same professional-grade units mentioned above.
    • AP100 Specific Filter: The triangular AP100 used a different 5-micron inner filter, part 50-877.
    Also Drill presses:
    Drill Press Rebranding List
    Tool Type Original Delta Model Shopmaster Rebrand Key Features
    8" Bench Drill Press Delta 11-950 DP100 5-speed; entry-level hobbyist model.
    10" Bench Drill Press Delta 11-990 DP200 5-speed; popular small-shop standard.
    12" Bench Drill Press Delta 11-985 DP250 Increased capacity and motor power over the 10".
    12" Laser Drill Press Delta 17-900 (equiv.) DP300L Featured crosshair lasers; benchtop model DP300L.
    12" Var. Speed Press Delta 11-090 (equiv.) DP350 Featured a Reeves-style variable speed drive DP350.
    16-1/2" Floor Press Delta 17-900 DP400 The full-size floor model version of the Shopmaster line
    DP400
    1" x 30" Belt Sander Delta 31-050 SA150 1/4 HP, 3450 RPM benchtop mini sander 31-050.
    1" x 30" Belt / 5" Disc Delta 31-080 SA180 (variant) Combination unit often sharing parts with the 1x42 line 31-080.
    Thanks for this. It will be helpful to some, and many if they are doing a search for cross-references .
    I was partial to Porter Cable back in the 80's and 90's, especially the routers.
      Here's a little AI compiled history of the Delta- Porter Cable association. For a while in 2009 Black and Decker, parent company of all, began to relabel various smaller Delta benchtop tools as Porter Cable to sell at Big Box stores. This ended in 2011 when B&D sold Delta off. I think internally B&D had a hard time reconciling all their overlapping product lines of storied brands once under one umbrella and giving each a niche.
      ___________________________________________
      When did Delta handheld tools begine being renamed as porter cable?
      Delta handheld tools were not exactly "renamed" as Porter-Cable; rather, the two brands were consolidated into a single operating unit starting in 2000.
      Click image for larger version  Name:	dataurl156800.png Views:	0 Size:	1.7 KB ID:	863065 Wikipedia +2
      Under the ownership of Pentair, the companies merged their headquarters and distribution to Jackson, Tennessee, in 2000. This led to a strategy where the brands were often marketed together as "Delta/Porter-Cable". Following the acquisition of both brands by Black & Decker in October 2004, the separation between their product categories became more distinct:
      Click image for larger version  Name:	dataurl156800.png Views:	0 Size:	804 Bytes ID:	863064 YouTube +3
      • Handheld/Portable Tools: Mostly moved under the Porter-Cable name. This brand was positioned as a "mid-tier" or "value-pro" line, sitting between the consumer-focused Black & Decker and the professional-grade DeWalt.
      • Stationary/Shop Tools: Remained under the Delta name.
        Click image for larger version  Name:	dataurl156801.png Views:	0 Size:	1.7 KB ID:	863063 Wikipedia +3
      Key Rebranding Moments
      • 2000–2004 (The Pentair Era): The brands functioned as "sister companies" with shared service centers and combined catalogs, though they kept their individual logos.
      • 2005–2009 (The Black & Decker Era): Delta's smaller portable power tools were largely phased out in favor of Porter-Cable counterparts to avoid internal competition with DeWalt.
      • 2009 (The "Identity Crisis"): Around this time, some traditional Delta stationary tools (like small band saws, jointers, and planers) actually began appearing with Porter-Cable branding for sale at big-box retailers like Lowe's.
      • 2011 (The Brand Split): Stanley Black & Decker sold the Delta brand to Chang Type Industrial (TOTY) while retaining Porter-Cable. This completely separated the two companies again.
        Click image for larger version  Name:	dataurl156801.png Views:	0 Size:	2.0 KB ID:	863066 Sawmill Creek Woodworking Community +6
      Pro Tip: If you have a handheld tool with a Delta logo from the late 90s or early 2000s, you can often find the identical replacement part by looking up the equivalent Porter-Cable model number from that same era.
