How high do you set your table saw blade?
    • 22106
    How high above the workpiece do you set the table saw blade height? Through cuts, obviously.
    Multiple answers allowed
    11
    as little as possible (i.e less than 1/8")
    0%
    0
    1/8"
    18.18%
    2
    1/4"
    36.36%
    4
    3/8"
    9.09%
    1
    1/2"
    0%
    0
    1/2 to more than one inch
    0%
    0
    All the way up
    0%
    0
    3 teeth showing
    0%
    0
    5 teeth showing
    0%
    0
    where ever it was on last cut (don't change it if I don't have to)
    0%
    0
    Depends on cross cut vs. rip cut
    0%
    0
    Set bottom of blade gullet at top of wood
    54.55%
    6
    The poll is expired.
    • 22106
    I like the top of the blade not too low... that way the top is cutting with some downwards force instead of straight back to wards the direction of
    feed.
    • Jim Frye
      • 1364
      • Maumee, OH, USA.
      • Ryobi BT3000 & BT3100
      I leave the bottom of the gullet just showing above the workpiece, and I use a ZCTP.
      Jim Frye
      The Nut in the Cellar.
        • 2812
        As I was taught, way back in my High School woodshop class (1960), that on a table saw, you always set the blade so the bottom of the blade gullet is at the top edge of the stock you're cutting. That ensures that the cut is clearly through the wood, and gives maximum advantage to the blade teeth to properly shear the surface. And, when you are through with the project, you lower the blade below the table, even with the blade guard on. I then un-plug it.
          LCHIEN commented
          I added that option... I don't think you can go back and change your vote, tho
          Lowering the blade and unplugging, good safety practice!
