Chisel recommendations?
  • David D
    • Dec 2009
    • 65
    • Richmond, VA
    I am learning that I need to start procuring some decent chisels, but man, you can spend some SERIOUS money on these things! I own ONE chisel right now (a 1" Stanley Contractor Grade), and would like to start buying some decent ones, but have no idea where to start.
    Any recommendations?
  • jussi
    • 2162
    I really like my veritas PM-V11 but they are pretty spends especially if it's your first non-beater chisels. I initially got the Narex chisels and really like those. A lot of stores care them.
    • David D
      • Dec 2009
      • 65
      • Richmond, VA
      I saw the Narex chisels on Lee Valley and liked the price. Good to know you have a positive experience with them.
        At the same time you are looking for chisels, look for a decent sharpening system.
        A sharp chisel is so much better than a "reasonably sharp" one.
        • David D
          • Dec 2009
          • 65
          • Richmond, VA
          Yeah, I tried sharpening the one chisel that I own, and messed it up. What's the best (easiest) sharpening system?
            When I started woodworking, I got a set of Irwin Marples chisels. They have served me well for nearly 15 years. When I got better, I bought a set of Japanese chisels. I reach for the Marples for heavy duty stuff and things like hinges and keep the Japanese chisels for cleaning up dovetails.
            http://www.amazon.com/Tools-Marples-...arples+chisels
            Beyond getting chisels, it's more important that you learn how to sharpen. I still use the scary sharp method--sandpaper on a glass plate--with an angle honing guide.
            http://www.amazon.com/Robert-Larson-...bxgy_469_img_y
              • 3126
              Funny you should ask ...
              Sharpening-Woodworking-Chisels
              The method Sam describes in the article is the method I've used for years and it's fast, easy, and inexpensive and less messy than anything wet. I bought a kit at Rockler that has everything you need for $40.00 less a penny. Item number 25041
              • David D
                • Dec 2009
                • 65
                • Richmond, VA
                Thank you for all the replies! I'll check out the sharpening links as well.
                  • 2812
                  David,
                  I too use the Narex chisels, purchasing mine from Lee-Valley. They are pretty decent quality, with very good hardwood handles and ferrules. Really decent size, well made blades and the handles are very comfortable in the hand to use. The Lee-Valley variety that I have are dark-handled and rather handsome (if that matters). To date I have six of the standard bevel-edged, a pair of skew's, and six of the mortise chisels. These were purchased as individual chisels, in the sizes that I would normally use. They do 'sets' but no sense in getting sizes that you may never need. http://www.leevalley.com/us/home/Search.aspx?action=n
                  Back in 2003 (when I retired) I started updating my woodworking tools and at that time I purchase a four-piece set of Marples from Home Depot. At the time they were made in Sheffield, England and the steel was pretty good. They had blue plastic (high-impact) handles with steel caps. However, soon thereafter they started sourcing them from China and I've read a couple of reports (including one photo of a split chisel) that the steel is poor. While my particular set of Marples has held up, the steel has stained considerably (here in NY the humidity is ridiculous), despite being well oiled. My Narex chisels have not weathered at all.
                  As far as sharpening is concerned, basically a well-made chisel will only require a bit of touch up. For that, I use a Veritas honing guide ( http://www.leevalley.com/US/wood/pag...72,43078,51868 )with wet/dry emory paper (3M auto-finish type) taped to a granite tile. A lot of the guys use this method ("Scary Sharp" ) using a piece of glass. For me, the granite tile is far more durable.
                  If you want a less laborious sharpening method, a power sharpener is the way to go... but they can be considerably more expensive. Grizzly has a very nice wet sharpener for around $150. (http://www.grizzly.com/products/10-W...tion/T10010ANV ) The European manufacturer Tormac sells the same design for significantly more and it is very popular. There's also the "Worksharp" which has a fairly unique design and is probably faster than most sharpening methods. It sells for about $200 or so, depending on the retailer. (http://www.worksharptools.com/sharpe...er-ws3000.html)
                  I hope this helps,
                  • David D
                    • Dec 2009
                    • 65
                    • Richmond, VA
                    It's good to hear another positive experience with the Narex chisels as I really like the price. The scary sharp sharpening method looks like the way to go for me as well. I like the granite idea, I will definitely use that. Thank you!
                      My "good" chisels are footprint brand. I think the are still sold but I don't know that they are the same quality. I got mine about 20 years ago. I use a Work Sharp 3000 to sharpen them and knives. It uses sandpaper stuck to glass discs turned at a low speed. Pretty painless way to do it.
                        I also have a set of the Sheffield Marple chisels as my main users. For rough work, or if I'm not sure what I may find buried in the wood, I have a set of old Stanleys. For finer work I have a set of Sorbys that the wife bought as a Christmas present several years ago.
                        • durango dude
                          • Mar 2011
                          • 937
                          I bought a starter set from Woodcraft a few years back.
                          (currently sold as Wood River Utility Set) They're good but not great.
                          I can't really complain - they're $39 for the set, now ---- and I bought them on sale for $25.
                          Almost identical set is being sold by Peachtree Woodworking - so I'd hazard a guess
                          that they're produced in the same factory.
                          They don't keep their edge as well as better chisels.
                          I think I'd go to Highland Woodworking and buy a Narex set.
                          There's one catch - the Narex chisels are labeled in metric,
                          so I'm not sure how well they cut standard width (joke)
                          • durango dude
                            • Mar 2011
                            • 937
                            duplicate post
                            • David D
                              • Dec 2009
                              • 65
                              • Richmond, VA
                              I suppose I should get a standard set AND a metric set so that I'm equipped to build European style cabinets! LOL
                              I've decided to buy the Narex chisels from Lee Valley. I think they're made to Lee Valley specs and are Imperial sized anyway?
