Which digital caliper?
  • guycox
    • 360
    • Romulak, VA, USA.
    Global Economy - Calipers.
    Look at it this way, in a global economy how many digital caliper manufactures can there be? I'd venture a bet that they all come from the same factory.. The only exception would be if you bought a Starret - and even then, the sensor and display would be the same as the all the other ones. The engineering costs to design and manufacture those components would be insane.
    Guy Cox
    Life isn\'t like a box of chocolates...it\'s more like a jar of jalapenos.
    What you do today, might burn your butt tomorrow.
    • JSUPreston
      • 1189
      • Montgomery, AL.
      SR44 are expensive and hard to find ( I seem to remember $3.50 each several years ago). I buy 2 cards of 10 LR44 for a buck to a buck and a half each card including free shipping (usually from china and it takes a couple of weeks) and don't worry about the cost anymore. Alkalines should have fairly good shelf life in general (several years) due to low self discharge so don't worry about keeping the extras around.
      Sometimes at Michaels or Hobby Lobby you can also find them in bulk. Used in a lot of toys, advertising buttons, novelties and gizmos with LEDs etc.
      http://www.ebay.com/sch/i.html?_from...ttery&_sacat=0
      quantities from lots of 5 to 100.
      I never could find the SR44 at a decent price. I read somewhere that the LR44 may cause some inaccuracy in digital calipers. However, I'm usually more inaccurate than the margin of error according to what I read, so I did the same thing and bought 10 or 20 off the Bay for just a few bucks.
        Originally posted by JSUPreston
        ''' I read somewhere that the LR44 may cause some inaccuracy in digital calipers. ....
        that's highly doubtful. these battery operated digital gizmos are made to operate with the battery voltage changing slightly over time as the battery is depleted.
        anything with alkaline cells is designed to work from about 1.1 or 1.2V to 1.6V
        the SR44 covers about the same range. So I would not expect any difference.
        The calipers measure distance by tracking a printed grid so its truly digital. Does not rely on a voltage measurement. Only a digital circuit to count the grid.
        • JSUPreston
          • 1189
          • Montgomery, AL.
          I figured that was the case as well. I think I may have read it on a battery vendor's site. They probably carried the SR44, which is why they were pushing it.
          • lrr
            • 380
            • Fort Collins, Colorado
            • Ryobi BT-3100
            I have two HF digital calipers. The 12" model does not burn thru the batteries. I do tighten the lock screw to keep vibrations from turning it on (has happened a few times). The 6" model I have does consume a battery pretty quickly.
            It is tempting to buy try another brand, but may have to jsut go find the cheap LR44s on eBay.
            • radhak
              • 3061
              • Miramar, FL
              • Right Tilt 3HP Unisaw
              I ended up buying the one from Amazon, and it's pretty good, but frankly, it's no better than the one from HF. It has auto-off, but not auto-on, which the HF one had.
              So, I guess with the cheaper price and additional feature, the HF one scores more.
              - Aristotle
                i'd give up auto-on for more battery life. What's the use of auto-on if the battery is dead?
