New BT3100 owner
  • nkawtg
    Handtools only
    • Nov 2014
    • 1
    • Las Vegas, NV
    • Delta 36-725
    New BT3100 owner
    Hi, I just picked up a BT3100 this week and I'm interested in attaching a router to the router table.
    My questions are:
    What is a good all around router to use for this system?
    What accessories if any do I need to purchase?
    The saw looks fine mechanically, though it's pretty dirty.
    What do you all recommend I use to clean the saw and accessory parts?
    Thanks all
  • tfischer
    • 2349
    Most any router can be mounted. Back when the saw was in production there was an accessory kit you would buy which had a router mounting plate, a 2-piece fence, and a clamp that helped stabilize the accessory table.
    The mounting plate had several different hole patterns for Ryobi routers of that day, and mated up with the 4 screw holes in the accessory table. I used to use it with a matching Ryobi router, but when that died I picked up a Ridgid which didn't have the right hole pattern, so I simply drilled and countersunk proper holes into the mounting plate that did work. You could certainly fabricate your own mounting plate if you can find a piece of aluminum or something else sturdy but thin.
    The included fence and guard were inaccurate and worthless. I built my own fence based on some plans, that clamps to the main rip fence. I can post pics here if anyone's interested.
    You're supposed to use the clamp to keep the table from shifting, but I've never had that problem and rarely use it.
      If you use the rip fence for a router fence, you need the extra clamp to secure the back of the aux table to the back rail or the table will move.
      the BT3 faq has an extensive discussion of routers with the BT3 (see my sig line below).
      • tfischer
        • 2349
        That's what I was talking about... I've rarely used the clamp and the table never moves for me.
        • Mr__Bill
          • 2096
          • Tacoma, WA
          Not having the mounting plate and in a hurry I drilled the table for my router. Counter sunk the holes and use a piece of gasket material between the router base and the table underside. Must be 4 or 5 years without a problem. You really have to make sure the router is centered in the big hole when drilling your new mounting holes or those little plastic insert things won't center on the router bit.
          frugality is a way of life not a fault
          • tfischer
            • 2349
            Ah I forgot to mention those. Yeah, they came with the accessory kit too. And you'll want them, or some replacement for them
