The Price of Precision
  • durango dude
    • Mar 2011
    • 937
    Just received a promo from Woodcraft ----- marketing the special
    setup blocks ----- holy smokes!
    http://www.woodcraft.com/Product/132...iner-Case.aspx
    There's some fairly reasonable alternatives out there:
    a) Veritas makes some setup blocks:
    http://www.leevalley.com/en/Wood/pag...240,41064&ap=1
    b) Kreg makes some setup bars that I own
    That said - I have a commentary ----
    Watch a video of Sam Maloof cutting something, some time.
    You'll notice something ----- I've never seen him measure anything!
    Where's this leave me?
    I'm not spending $400 to measure with a micrometer - when I cut with a sledgehammer.
    http://www.mscdirect.com/product/det...63015&fromRR=Y
    For reference. I'm sure there are less expensive more accurate options available.
    • Cochese
      • Jun 2010
      • 1988
      Even the guys on FOG are complaining about the price. That's when you know it's too much.
        They are a lovely shade of red!
        • durango dude
          • Mar 2011
          • 937
          Here's precision layout for you. Watch him at around 0:19 draw a line..........
          https://www.youtube.com/watch?v=amOGCMOq_Aw
          • lrr
            • 380
            • Fort Collins, Colorado
            • Ryobi BT-3100
            Woodpeckers must count on the short deadline for ordering those setup bars to get most folks to spend so much for them.
            I do like Woodpeckers stuff and have 3 of their rules of varying lengths, and I bought one of their metric rules because one project I did had so many offsets it was simpler to use metric instead of adding and subtracting fractions. But I would have never bought them if they were "One Time Tools", since I've bought them over time. I plan to add more in longer lengths and will likely buy both Imperial and metric, but if I had to buy everything I thought I'd want all by a looming deadline, I would have passed on them.
            There are older One Time Tools I want and I'm on their mailing list if these items ever return. I've been waiting a couple years now and figure it will never happen. Kind of irritating ... I'm 62 and that clock is ticking!
              I don't think I need a complete set of setup bars, I find the fractional 1/8, 3/16, 1/4, 5/16, 3/8, and 1/2" enough for offsetting things from a fence or whatever.
              And if you want to be cheap then just use a drill bit set.
              Or buy some aluminum square bar stock at the local hardware store for about a buck a foot. and then you can cut off 2" pieces and make six sets. These are quite accurate.
              If you have a transfer punch set, that works too, just be advised that they are 3-5 thousands undersized to be able to slip in a hole of the size they are marked.
              I like measuring gizmos and tools but I don't really have a desire for one of the sets being mentioned. I also have one of the commercial setup bar sets from Rockler, I think, brass in a nice plastic case, about $19 bucks. with the standard 1/8, 3/16, 1/4, 5/16, 3/8, and 1/2" set. You can stack them for in-between sizes.
              • jussi
                • 2162
                I have a few of woodpeckers one time tool but I'll be staying away from this one. I'm very happy with the veritas set up blocks.
                • Condoman44
                  • Nov 2013
                  • 182
                  • CT near Norwich
                  Same for me in that these are just to spendy and I have not had need for anything like this in the past.
                  • All Thumbs
                    • Oct 2009
                    • 322
                    • Penn Hills, PA
                    • BT3K/Saw-Stop
                    .001" precision isn't actually very precise.
                    When working metals things are typically held to the "tenths" or 1/10000 or .0001".
                      Agreed - on metal or cast items. But very good on wood. Wood cannot be expected to be operated with the tolerances of metal.
                      There is a thread here some 10+ years ago in which I had a pict of a Japanese friends' wood shavings. (The pict is now gone). The shavings were so thin that you could easily read magazine print through the ribbon.
                      I commented on that to Maeno and took some shavings home to make that picture. Maeno said, (in Japanese of course) "Oh, that plane wasn't as sharp as it could be. I will call you to come back when I sharpen it."
                      A few weeks later, he called and I went back to his house. Bear in mind that Japanese planes are not adjusted by a knob or lever, but by tapping the sides or ends of the block lightly with a hammer, causing minute movements of the cutter - and eyeballing the results.
                      Well, Maeno did that with me watching. Then he said (had to repeat a couple of times for me to understand) "This piece of planed wood has been setting out for a couple of days. After a piece of wood is planed and is flat, humidity changes over a couple of days will raise the soft vs hard of the grain. What once was flat will now be ridges between the two." With that, he planed away the raised ridge of the soft wood and little strings/strands came off. That had to be close to 1/5000 of an inch or even up to 1/10000 as you mentioned.
                      He eyeballed the settings and came up with that, no trial and error!
                      • tfischer
                        • 2349
                        LOL it's like golf clubs... I could buy a $20,000 set of golf clubs but I"m still going to suck. I could buy these setup blocks and I'm not going to be much more accurate than I am now.
                        Someone here used to have a signature, something to the effect of "Measure it with a micrometer, mark it with a crayon, cut it with an axe" lol
                        • trungdok
                          • Oct 2012
                          • 235
                          • MA
                          And that's when I would pick my jaw off the ground
                            For wood, I'll settle for 1/32 inch accuracy, and celebrate 1/64. My digital/fractional caliper has 1/128 setting, which is ~0.008 inch. (This is also a point of amusement, since the metric setting has 0.01mm increments, which is ~0.0004 inch).
                            So IMO this set is overkill for wood. Hard to think of a circumstance where using drill bits, a caliper or one of these wouldn't produce the same results more economically. Of course, you have to buy batteries, but you can probably get a lifetime supply for the difference in price.
                              • 2812
                              I agree... I think we often don't see the material for what it is. Many of us get the idea that 'machine-shop' precision is essential to good workmanship with woodworking.
                              Perhaps, some of us can reach that kind of precision (+/- 0.001), and if so I certainly salute you; but for most of us, I think, just reaching dimensions to the "64th" or maybe even "128th" of an inch is a worthy achievement.
                              The Woodcraft price does seem to be quite excessive, IMHO, but then knowing how many of us are, I am sure they're marketing dept knows full well that there will be a number of buyers.
                              For me, there are a number of 'precision' items that I've used, like the Rockler' brass set-up bars I use for the router table. I also have a set of 'parallel bars' and a 'transfer punch' set which I got from HF. (I believe the latter was a recommendation by one of the predominant members here on the forum, earlier this year.
                              The question of course is setting you own need for 'precision', while keeping in mind how the materials you're working are going to change over time because of environmental conditions, like humidity, temperature, etc.
