what do you cut sandpaper with?
    • 22109
    I now have what seems to be a large number of 4" x 36" strips of sandpaper (used to be belts until the glue gave up). Guess they're going to become
    sanding blocks.
    So, what would you cut them with?
    Good Scissors? Seems like it would destroy the scissors pretty fast.
    $2 (el cheapo) scissors from Loews?
    Your wife's sewing scissors (when she's not looking)?
    Sheet metal cutters (tin snips)?
    Exacto/box cutter and guide?
    Make a sandpaper cutter with a hacksaw blade edge to rip it over?
    or???
  • Cochese
    • Jun 2010
    • 1988
    I'd try a guillotine trimmer personally, one of the heavy duty ones. Makes it dead simple and replacement blades or sharpening should be a simple matter.
      Broken belts that I use for hand sanding I usually just tear a piece off. If I need a cleaner edge I either use scissors or cut it on the backing side with a utility knife. the utility knife works good and blades are cheap. I buy rolls to cut strips for the drum sander from and made an aluminum template to cut the ends.
      When I need to cut down sheets of sandpaper, I have an old paper cutter in the shop dedicated for that job.
        • 8807
        Similar to Don. On most sheet SP, I usually cut from the back side with a knife.
        If I am cutting down 400 or higher, I will usually use the cheap sissors that HF gives away at sales. I have a bunch of them.
          • 22109
          ah good points made, cut the backside with a knife and avoid the grit, you can tear it the rest of the way.
          • Stytooner
            Roll Tide RIP Lee
            • 4301
            • Robertsdale, AL, USA.
            HF often has coupons for free utility scissors with purchase like Hank mentioned. I have a couple pair of those in the shop as well as some Fiskars shop scissors. The HF's cut sandpaper well. The Fiskars will not see sandpaper.
            • lrr
              • 380
              • Fort Collins, Colorado
              • Ryobi BT-3100
              I use the HF scissors for cutting sandpaper, also. I think I bought the last couple pairs for 99 cents. I've seen the same scissors at other stores for $6.99, but they do come in nicer packaging ...
              These scissors, and the box of 100 nitrile gloves, are about the only thing I buy anymore from HF. I did buy one of their cordless drills for my sister-in-law ...
              And I do occasionally buy from them if I need a tool that will see limited use, like an angle grinder. When the neighbor needs to borrow a tool, he is offered up one of the HF tools I have.
                I've been using a linoleum knife for many years. Fold the paper grit-out, and cut from inside the crease.
                  • 2813
                  I've never had to cut belts, but for other sandpaper I usually score the paper side with a utility knife, fold back and forth a couple of times, and tear. Sometimes, I might have to use a straight edge to keep the tear even.
                  Everytime I go to HF, my wife seems to have a coupon for something free (as well as at least a 20% discount coupon).
                  She gets so much "free" stuff, I can't keep track. But among that must be at least a couple dozen pairs of those scissors. (ten or so meters, screwdriver sets, gloves, etc.).
                  The scissors are pretty decent and if you foul one up, it can be a throw-away. But still, I keep using my old methods for cutting sandpaper.
                  • Daryl
                    • 831
                    I fold back and forth a few times, then tear across the bench top.
                    • gerti
                      • 2233
                      • Minnetonka, MN, USA.
                      • BT3100 "Frankensaw"
                      Either a cheap pair of dedicated scissors, or when that isn't handy any sharp edge: formica or particle board, or a cast iron surface with a sharp edge (lathe bed, band saw table). Paper side down, hold on strong and pull down sharply one edge of the paper. Works most of the time, sometimes it doesn't tear clean. Usually when it's the last sheet and there are no spares..
                      • wardprobst
                        • 681
                        • Wichita Falls, TX, USA.
                        • Craftsman 22811
                        I like dedicated cutters and have made three. One is mounted on a file box I keep sandpaper in, just a hacksaw blade bolted to the top. Slide the paper under, pull up and you are done. The other two are mounted on blocks of UHMW plastic and sized for sanders we own- insert paper under hacksaw blade, line up with edge of block then tear. It's fast and old hacksaw blades are easy to come by here.
                        DP
                        www.wardprobst.com
                          • 22109
                          so, no one sneaks their wive's sewing scissors, eh?
                          • Stytooner
                            Roll Tide RIP Lee
                            • 4301
                            No. My dog house doesn't have a beer fridge.
                              This is what I do. Create a crease where I want to cut it, then cut from the back side.
