Breaking Sanding belts
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    Not sure how well it works, but did find this link.
    http://www.specialabrasives.com/ptx_pipe.htm
    If they have it down under, then we should have it up over.
    I also read that the seam tapes are vulcanized in place by manufactures meaning ultra high, short term, pinpoint heat to join the belts. I'm sure some sort of prep is also required.
    PS, read the very last post in this thread.
    http://www.britishblades.com/forums/...-Sanding-Belts
    That is what I suspected as well. Special sauce.
    • rcplaneguy
      • Nov 2012
      • 37
      I tried gorilla glue on a 6x48" shopsmith belt. Glued, clamped, let set for 2 days. It left a raised bump that was annoying but it kept the belt in service for about 5 minutes before failure. Tried it again but it only lasted a minute. Gave up after that.
      • Bruce Cohen
        • 2698
        • Nanuet, NY, USA.
        Loring,
        The same thnk happened to me. I unearthed a box full of belts (Craftsman) I never knew I had. The belts must have been 10-15 years old. After the first 4 broke, I just tossed the entire box and got new ones (Norton). It just didn't pay to play around with the old ones, even if I may have found some that still held together.
        Bruce
        Samuel Colt did"
        • lrr
          • 380
          • Fort Collins, Colorado
          • Ryobi BT-3100
          These belts are butted and taped, not overlapped and glued.
          Sounds like it is time to make that hand sander tool that uses old sanding belts.
          Seriously though, at work I've seen one in the shop, but not looked closely at it since our projects seldom involve sanding. I think it has a spring that tensions the belt around both rollers. Since a manual sanding pad would just hold a belt and not employ any belt rotation, you could do something like staple the ends together, or just make a clamping-style sander pad that takes the broken belts as-is.
            • 22106
            that's the secondary plan...
            cut some 2x4 blocks about 5" long and cut the belts to about 7" long and wrap around the 2x4 and staple to the ends to make some Quick and dirty sanding blocks. I should be able to make...30 or 40 of them
            • big tim
              • 546
              • Scarborough, Toronto,Canada
              • SawStop PCS
              Loring, have you tried repairing them with filament tape, probably stronger than duct tape?
              Good luck,
              Tim
                • 22106
                Good luck,
                Tim
                The tape doesn't tear, the adhesive pulls off, first.
