HF Central Machinery Drill Press Model 844
  • svperil
    Handtools only
    • Nov 2013
    • 4
    • Bel Air, MD
    • Ryobi 3100
    Does anyone have one of these OLD CM 5-speed drill presses?
    I need a replacement for the v-belt but can't find a part number/vendor.
    HF customer support has been unable to help.
    If you have the old best and it is simply broken take it to an auto parts store, if not then measure with a piece of 3/8" rope. Take the rope to the same store. They should be able to use their belt measuring device to find one close enough.
      • 22109
      I agree with black wallnut. THose V-bets are virtually the same as automotive belts. Bring the pieces to an auto parts store.
      Length usually not all that critical as the motor housing usually moves some in a two-pulley DP to take up slack.
      • Lonnie in Orlando
        • 649
        • Orlando, FL, USA.
        I use link belts on my 16.5" HF drill press and 14" HF band saw. No vibration from v-belts that have aquired a set in them. Adjustable to any length. A package of one belt is long enough to make two drill press belts.
        > Link Belt
        - Lonnie
          • 22109
          > Link Belt
          - Lonnie
          a good alternative. Maybe better!
