Round Or Flat?
    Round Or Flat?
    For mallet faces (if you have them and use them) , do you prefer one over the other?
    Mike,
    If by round face you mean this carver's mallet, I really like and use it the most.
    If by flat face you mean this carpenter's mallet, I think I use it less, but useful for when you need the flat face.
    Also reach for the deadblow mallet every now and then.
      Mike,
      You got it covered. I should have been more explicit I think. Like maybe saying round or flat striking faces.
      • phrog
        • Jul 2005
        • 1796
        • Chattanooga, TN, USA.
        I turned one like Bill referred to as a Carver's Mallet (round with a slight taper getting smaller toward the handle). (First thing I ever turned) Made it from an old shagbark hickory tree I had to have cut down. I use it all the time.
        Edit: The problem I see with a carpenter's mallet is that you have to look at it to make sure you have the face turned correctly and it breaks your concentration on what you're doing.
        Richard
          • 2812
          I went through a period a couple of years ago when I was making a few support benches for my little shop. I had decided to make all the joints M & T and was thus doing a lot of chisel work, all using a flat-faced mallet (actually a hard rubber "tire-like" mallet and Marples chisels.
          After that lengthy process, I decided I'd buy proper "Mortice" chisels and a carpenter's mallet. Wouldn't you know, that since that purchase all I've done with those is cut a couple of practice mortices! I do like the rectangular head of the mallet and for me it's a terrific to have the right tool for the job (Crown - Sheffield England).
          Now if only I'd get back to a few projects that would let me use it.
            Maybe the best of both types would be one with both profiles. Here's a suggested top view...
Name:	two faced.jpg
            • phrog
              • Jul 2005
              • 1796
              [ATTACH]18866[/ATTACH]
              Maybe you should patent that and call the Capital "D" mallet.
              Richard
                A capital "D" mallet...brilliant.
                • gsmittle
                  • 2793
                  • St. Louis, MO, USA.
                  Somebody (can't remember who) markets a small brass mallet with that type of head.
                  I use a round brass head mallet when I use one, which isn't often.
                  g.
                  Smit
                  "Be excellent to each other."
                  Bill & Ted
                    g.
                    Shop fox:
                    Veritas Leevalley.com
                    Diefenbacher.com
                    Peachtree PTreeusa.com
                    not exactly small here's a 2-lb whopper of a mallet from Highland woodworking
                    DIYers Lumberjocks.com
                    I like them, they all look pretty.
                      • 2812
                      My rubber mallet was just a pretty cheap alternative to buying the right tool for the job:
                      It worked good enough with its 16 oz head. About the only other hammers that I had was a homemade oak-headed one that I had made, but it didn't have the weight; and of course, a few steel hammers which I would never use, even on the cheapest of chisels.
                      This rubber mallet was only something like $3 or $4 I think. Can't remember where I bought it or even how long I've had it.
                      • scmhogg
                        • 1839
                        • Simi Valley, CA, USA.
                        I prefer the round carvers mallet. The weight allows a short controlled stroke, or tap. I turned mine out of a piece of solid brass and used Compreg as a handle. It is heavy.
                        Some time ago, I made a bunch of Japanese style long handled mallets. I have rarely used them since I made the round mallet.
                        Steve
                          Steve
                          Nice work Steve...looks great.
                            I've been thinkin' about what to call it. The "capital" could be left out and just call it a "D" mallet, just like they call "D" rings.
                            • phrog
                              • Jul 2005
                              • 1796
                              Do I get any credit for the name on the patent application ?
                              Richard
