corrosion on battery contacts
  • ironhat
    • 2553
    This problem is on a Ridgid, 18v, NiCad, hammerdrill. It's getting up there in age and last year I sent it off to have the batteries rebuilt at Primecell. Ever since then I've had problems with battery contacts corroding to the point that the drill won't even work. I cleaned them off with a baking soda solution and rinsed with distilled water, being careful to not let any get into the case and that was about six months ago. I never had this issue with the factory batteries. Then again, the past few years I haven't been using my tools much. Would di-electric grease protect the contacts from corrosion and still allow flow of electricity? Is there anything better? Should I treat the contacts in the battery as well as the ones in the drill body?
    That's the story. What's the verdict?
    Blessings,
    Chiz
  • Dal300
    Banned
    • Aug 2011
    • 261
    • East Central Texas
    I would suspect a leaky cell. No other way you can have battery corrosion.
    If you still have a warranty, or even if you don't, contact the rebuilder and see if they'll stand behind their work.
    Otherwise, just send it back and have it rebuilt again, maybe at another rebuilder.
      I think Dal300 is right.
        I would just get a new battery.
          To answer the grease question - yes, that is something I have done on car batteries to keep them from corroding.
          • ironhat
            • 2553
            Thanks folks. The battery is packed for the mail.
            Blessings,
            Chiz
              What's the charge plus shipping for the re-do?
