Air nailer
  • JSUPreston
    • 1189
    • Montgomery, AL.
    Air nailer
    My 18 gauge finish nailer is getting a little long in the tooth. Misfires a lot, doesn't seem to do a well with 2" brads as it used to, etc. It's an old Craftsman from about 10-12 years ago. It's been a good unit, but I'm spending more time maintaining it than using it.
    I noticed a 3 pack of nailers for $70 at HD. It's this package:http://www.homedepot.com/h_d1/N-25ec...1#.UIMJf1EYqZQ
    Anyone have any experience? I'll be retiring the old Craftsman as soon as I can get a good replacement.
    I've looked at the one at HF, and it looks just like the 18 gauge Campbell Hausfeld that I got with my little compressor. I've never liked it.
    You might try filing off the end of your drive pin flat. After a lot of use it can get peened just enough to misfire.
    • jdon
      • Feb 2010
      • 401
      • Snoqualmie, Wash.
      I have an older style (#66995, blue/black) HF 18g brad nailer- misfires frequently. I don't use it enough to be much of an issue so far, just a nuisance. I don't know if their new model is better, or a cosmetic change.
        Not sure how useful the "thin wire stapler" in the kit would be for me. I've had great usefulness (i.e., no misfires) out of the individual items I've gotten from HF, but if you're leaning toward HD, you might want to look at this 3-piece combo - no experience with the "Surebonder" brand, but assuming you don't already have a 16g nailer, it may be more useful than the thin wire stapler.
        • JSUPreston
          • 1189
          • Montgomery, AL.
          Just for more info, my nailer is the older, black version of this one:
          http://www.sears.com/craftsman-18-ga...9&blockType=G9 When I said misfires, I meant it's firing blanks when I try to use a 2" brad. I've only had a few true misfires and jams.
          I do have a 16 gauge Ridgid that I've never used. It came with a miter saw that I bought years ago. I wonder if I should make that one my go to gun.
            Does it leak air at all?
            You could, but 16 ga might be a bit much for some fastening.
              the question is, do you need a 18 ga brad nailer and 2 staplers? (not really three nailers).
              the narrow gauge stapler is for hanging like masonite sheets and pegboard and stuff like that, maybe 1/4" plywood and panelling where appearance is not prime concern. The fine wire wide crown staplers are more for hanging fabrics or upholstery use.
              An OK kit if that's what you need. I probably fire one staple for every 100 brad nails I shoot... staplers are not my go to fastener altho they have their place (won't pull out as easily as brads for example when fastening thin sheet material).
                In doing casework, cabinets, showcases, either painted, laminated with mica, or veneered, an 18 ga narrow crown stapler would be the major fastener.
                  I just went through at least a thousand narrow angle staples building a kitchen and they do hold well. I used a Hitachi stapler, works well enough.
                  I have used and still own three PC brand nailers - framing, finishing and brad and IMHO they are the best.
                  I have a Freeman micropin nailer thats nice, but not as good as the pc stuff. It works ok, but you have to manually adjust for the length of the pins. The feed pressure is not always strong enough and will allow the unit to dryfire. With headless pins this small, sometimes its hard to tell if you hit it or not...
                  If I were you, I would hit the local pawnshops and test out a PC 18 nailer, bring your own supply and hose and some scrap Ebay shows average prices for this unit around $15
                  • JSUPreston
                    • 1189
                    • Montgomery, AL.
                    I realized that the unit I had seen at HF was the 18 gauge nailer/stapler combo. So, after thinking about it for a couple of days, I picked up the 18 gauge nailer tonight. After tax, it was a grand total of $16.49.
                    I've got some molding I need to put up the next couple of days. Perfect time to try it out. So far, the one thing I don't like is that the safety is on the opposite side of the opening for the nails. Just something I'll have to get used to.
                    • tropicalarcadian
                      • Oct 2012
                      • 15
                      • South Florida
                      • Ryobi BT3000 13amp
                      i've used almost every name brand of air nailer and have been most pleased with Hitachi. As a rule i find all the rest of Hitachi tools to be mediocre. A 1/4" narrow crown is very nice to have. But, if you only need a low priced but faithful 18 gauge brad nailer, then i highly recommend a reconditioned Hitachi from CPO or BigSkyTool.
                      • tropicalarcadian
                        • Oct 2012
                        • 15
                        • South Florida
                        18 gauge, 2" Brad nailer, on sale for 33 clams 8)
                        http://bigskytool.com/Hitachi_NT50AE...d)___i320.aspx
                        • tropicalarcadian
                          • Oct 2012
                          • 15
                          • South Florida
                          and here is a stapler for 34
                          http://bigskytool.com/Hitachi_N3804A...)___i1051.aspx
                          Just a note btw, the stapler-nailer combo guns leave a staple wide hole even when you use brads, so it's better to have separate guns for your best looking work
                            Originally posted by tropicalarcadian
                            Just a note btw, the stapler-nailer combo guns leave a staple wide hole even when you use brads...
                            Isn't this issue correctable by reducing the pressure to the gun? My HF combo nailer/stapler doesn't have this issue with the pressure adjusted.
                            • Mr__Bill
                              • 2096
                              • Tacoma, WA
                              If you set the gun to put the brad below the surface then it does. The hole is as deep as the top of the brad, if the brad is just flush then there is no hole.
                              I have the HF 18 awg brad nailer too. The only time it misfires and no nail comes out is when it's out of nails
                              Bill on the left coast
