diff between segmented and continuous saw blades
  • Sweet Willy
    • May 2011
    • 195
    • Near Chattanooga, TN
    • ridgid 3650
    I'm looking to buy a new blade for my miter saw (you really don't want to know why). What I can't figure out or find info on is the difference between a "continuous" and a "segmented" blade for woodwork. I saw plenty of info on diamond and tile blades that was no help to me at all. Is one better than the other? If so, in what way?
    Thanks.
    Dennis
    Sweet Willy
    sigpic
    ????? never heard of those options for a woodworking circular sawblade. I think they refer to tile or stone cutting blades.
    just buy a Freud brand 60 or 80 tooth woodworking blade for crosscutting and you should be set. They will all have carbide teeth not diamond teeth.
    any of these saying miter saw or crosscutting should be a good choice:
    http://www.amazon.com/s/ref=nb_sb_no...aw+blade+freud
    look at the ones that say miter saw and/or crosscutting or cutoff in their title and have 60 or 80 teeth.
    I just did a search on amazon for 10-inch miter saw blade Freud to get that list.
    here's a link describing diamond segmented and continuous rim blades. - Like I thought, not for woodworking.
    http://www.dblades.com/diamond-saw-blades.htm
    Which type of rim to choose: A continuous smooth rim provides the smoothest cut in ceramic tiles
    and ornamental stone. Continuous castellated rim blades or super-jointed segments may produce slight chipping
    but generally have a longer life and lower cost per cut than continuous rim blades. Segmented blades provide
    the longest life and lowest cost per cut but are only suitable for work where chipping is not a problem.
      Are you referring to blades that have separated groups of teeth versus continuous circumferential teeth?
      • Sweet Willy
        • May 2011
        • 195
        • ridgid 3650
        Here are two links for two different blades I chose at random. If you scroll down and choose "specifications", look at the right side column for "rim type". This one (http://www.lowes.com/pd_96541-70-DW3...des&facetInfo=) says segmented.
        This one, however, say continuous (http://www.lowes.com/pd_103025-10314...des&facetInfo=).
        Just wondering what the difference is for blades cutting wood. I understand the difference with blades used to cut tile, etc.
        Thanks
        Dennis
        Sweet Willy
        sigpic
        • Skaning
          • Nov 2010
          • 63
          Just a quick heads up. Miter and Ras blades should be made with a slight negative hook to the teeth. That's a piece of info that is usually not included in any sales pitch at the retail level.
            Consider the source of the links... Lowes It's likely a misnomer.
            • BigguyZ
              • Jul 2006
              • 1818
              • Minneapolis, MN
              Yeah, I'm thinking their marketing department hasn't had too much experience with their own product...
