Should I keep this?
  • dtam
    • 137
    • santa clara, CA
    • delta 36-675
    Should I keep this?
    I just bought a Craftsman router in the clearance area at Sears for $27. It looks brand new, so it was probably a display model at one time. It's missing the fixed base, rod for depth adjustment, collet for 1/4" bit, and maybe some other accessories, but it has the collet for 1/2" bit. The model # is 320.17543. I haven't tried any test cuts, but the motor is able to turn on.
    I'm not sure if this is a good deal, and if I should keep it since I already have the Bosch 1617 router kit. What do you guys think?
    I would keep it. The are a lot of times where you will need 2 different router set ups on a project. With 2 routers you don't have to switch bits and try to get the settings duplicated.
    I have 2 routers in tables and 2 hand held routers. A couple of times I have had 3 different bits set up for the same project.
    • BigguyZ
      • Jul 2006
      • 1818
      • Minneapolis, MN
      For $27 I'd keep it.... absolutely.
      What I'm curious is if you can take it apart to get just the motor? I know that a lot of the Craftsman routers are exactly like some Ryobi or Bosch routers. I'm wondering if you can strip it to the motor, and get a Woodpeckers or Incra router lift that the motor will fit into. Then you'll have just about the cheapest router table setup you could get.
        I would keep it, it's a great deal for the money, even considering what you may have to buy.
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          when i've gotten in complete tools from sears, a call to CS has usually gotten me the missing parts gratis. i'd keep it,if only for dedicated use in a router table.
            you can probably replace the rod with a piece of metal rod from lowes, HD etc. cut to length and probably a standard dimension like 1/4" dia. or 6mm.
            THen you have a complete plunge router for under $30.
            collet you can look up on sears parts
            hears your router
            http://www.searspartsdirect.com/part...hdMod=32017543
            click on the edge guide, I think a 1/4" collet is item 110
            same nut (#40) as ont he motor which shows a collet (probably the 1/2" collet is #39)
            dooesn't say which is which, order 39 and 40 to be safe,
            • Cochese
              • Jun 2010
              • 1988
              I have that router in my router table, and it's done everything that I've asked it to. You got a nice deal.
              • Old Dutchman
                • Oct 2011
                • 38
                • Holland Mi
                • My BT3000
                I would!
                I have Craftsman routers and I like it a lot! I have used a Craftsman since 1969, That old router is still good! If it's the red top, They have been good. Check out last years magazines, and several have given Craftsman a good buy.
                I have Hope, and I am Thankfull! Consider WhoWhoGreated it ALL
                • os1kne
                  • 901
                  • Atlanta, GA
                  I'd keep it. You got a great deal. I don't think that you could get a router that good for $75, let alone $27.
