Ryobi AP1300 help please
  • Cochese
    • Jun 2010
    • 1988
    I've had this planer for about a year now, and lately I haven't been able to lower the cutterhead past about 1-3/8." The mechanism gets tough to turn at 1.5" and I'm afraid to try and force it to go lower. I know it can go down to as low as 1/4", so something is up.
    Is this as simple as cleaning and lubing the spindle? Looking for suggestions before I tear into it. Thanks.
    Now I know these machines aren't the same, but there may be similarities with the AP1301, which is the model I have...
    I had a similar problem, where the cutter head wouldn't go under 1". I fixed the problem by raising the head all the way up, and thoroughly cleaning the raise / lower screws, and shafts, then dry lubing them. You may want to get a blow gun in there as well and clean out anything that make be caked toward the cutter head... I tend to process a LOT of pine and cedar, and that stuff jams up my planer pretty often... Hopefully the AP1300 you have has the same problem. It was a very easy fix...
    • Cochese
      • Jun 2010
      • 1988
      User error this time. Thought I had disengaged the 'plane to...' lever. Oops.
      • natausch
        • Aug 2009
        • 436
        • Aurora, IL
        • BT3000 - 15A
        Done the same thing myself several times, so don't feel bad. The location of the height limit is very well hidden on the AP1300.
