New router at HF
  • Sawatzky
    • 359
    • CA
    New router at HF
    HF has a new router. It looks like a Porter Cable 690 copy, but is only $50. I am sure it is no PC, but for the price it does not look bad if you need another small router.
    http://www.harborfreight.com/power-t...ter-68341.html
  • phrog
    • Jul 2005
    • 1796
    • Chattanooga, TN, USA.
    Wonder if the PC 690 motor will fit it? My 690 has the old housing with a thumbscrew instead of a lever and it is very hard to turn the thumbscrew to make it tight. Also, my 690 did not come with an edge guide or 3/8" collet. If all these HF parts work with the 690, it might be worth the price for these parts alone.
    Richard
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      phrog, replace that thumbscrew bolt with a proper length ¼" hex bolt and one of these. I did that years ago with my, at that time, table mounted 690 and it worked like a charm. Rockler also sell similar cam levers.
        That sure does look like a 690, and 11 amps. Price sounds good. It would be interesting if some parts are interchangeable. Maybe there will be a plunge base available.
          I did the same thing but I got the lever from somewhere else that I can't remember. Works well and I really like it.
          • JoeyGee
            • 1509
            • Sylvania, OH, USA.
            If that is halfway decent, and you could use a 20% coupon, it would be a really good deal. I missed it, but are these in stores?
            • phrog
              • Jul 2005
              • 1796
              Thanks Dave and Hank. Didn't know there was such an animal available. Sure would make adjustments easier.
              Richard
                • 22106
                here's the rockler cam clamp part (2 for $9)
                http://www.rockler.com/product.cfm?page=10602
                • Knottscott
                  • 3815
                  • Rochester, NY.
                  • 2008 Shop Fox W1677
                  Shouldn't be any worse than the other HF routers, and might just be an improvement!
