My lunchbox planer is running rough
  • jnesmith
    • 892
    • Tallahassee, FL, USA.
    Hey:
    I have a Delta 22-560 planer. It's been a good piece of equipment until recently. It started running real rough; sounds like the motor is really struggling. It has gotten worse. I have greased the drive chains, oiled the roller bearings, and done everything else the manual suggests. Nothing has done any good. I shot a brief video so you can hear it.
    http://www.youtube.com/watch?v=1sW6gjIWFbo
    It sounds worse in person. It just does not sound right. I know very little about motors, so I don't have a clue.
    Does anyone have any suggestions?
    P.S.
    The brushes look fine.
    John
    • 22098
    doesn't sound like the motor is straining, sounds like a mechanical problem, like bad bearings or something is rubbing against something else.
    What happened before it sounded like that? rough use? or just been stored?
    • jnesmith
      • 892
      Loring:
      Thanks for the reply. I don't recall anything significant happening; it just seemed to get worse. It does occasionally sit for a month or more without use though. It did seem to plane adequately even after I started noticing the sound, up until yesterday. It now also seems to struggle feeding the stock through.
      Should I be able to turn the rollers by hand?
      John
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        With the noise being that pronounced I'd bet if you remove the covers the problem will be fairly easy to see.
          This was my first and main thought, but I also wondered if there is a brush armature problem.
            +1. Compared to my Ridgid planer, it sounds like your motor is spinning almost with no load. Sounds like gears grinding but I'm not sure if gears are involved in there. Definitely take the cover off to get a better look.
              OP, Update? Did you find out what was wrong? Did you fix it?
              • jnesmith
                • 892
                Hey:
                I never figured out what was wrong. (Although I also did not spend any more time trying to figure it out). I put it for sale on CL, with an explanation of the sound/problem. Some guy making a couple of paddle boards checked it out and bought it for $75. I think he was only concerned with it lasting long enough for this one job.
                I put the $75 towards a new Dewalt 735, and am now a very happy camper. (Except for that hole in my wallet)
                John
