Table Saw Value Question
  • Eagan
    • 190
    • bloomington, IN
    • rigid r4512
    Does this seem right? Is there any way the Harbor Freight saw is worth more then the Ridgid?
    Ridgid Table Saw - $549
    Porter Cable Saw - $549
    Harbor Frieght - $699
    • 9568
    Even with the 20% off coupons, they simply won't be selling many of those at prices like that!
    • toolguy1000
      • Mar 2009
      • 1142
      • westchester cnty, ny
      no, especially if you remember, as i believe i do, when HF had them regularly priced @ around $400 a few years back.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Which HF saw?
        This is an HF saw that's probably worth more than the PC or Ridgid:
        • BigguyZ
          • Jul 2006
          • 1818
          • Minneapolis, MN
          What item is that? looks pretty slick, actually.
          As far as the contractor HF saw for $700, I would point out that the extension wings are cast iron, vesus stamped steel (though, they're not solid. I'm not a fan- my Cman has the same type of wings). ALSO, at least on the spec sheet, the motor is 3HP, rather than the 1-3/4 that the Rigid or PC probably are.
          • Cochese
            • Jun 2010
            • 1988
            Originally posted by Knottscott
            Which HF saw?
            I don't even see that one.
            I see this: http://www.harborfreight.com/10-inch...saw-46813.html
            It's definitely not worth the price of admission.
            • natausch
              • Aug 2009
              • 436
              • Aurora, IL
              • BT3000 - 15A
              Is that a Biesemeyer on a HF Saw? What is the world coming to.
              • Knottscott
                • 3815
                • Rochester, NY.
                It'd be a cold day in he!! that I'd pay $699 for that HF contractor saw!
                The cabinet saw may be discontinued now...it was a hot item in the $700 range a couple of years ago. With discounts, some were picking it up for < $500. The reports I read were pretty favorable. The fence was a Biese clone, but definitely not a real Biese.
