Changing knives on my TP. Just one to go
  • ironhat
    • 2553
    I have read all of the threads on the web (yes, I have read the entire web) and nowhere does it tell how to get the screws out of the knife retaining bar of the Delta TP200. I have but one to go and it's beginning to round over the shoulder. The only wrench that fits is the one that come with it since it is a bit thinner.
    I put it to bed last night with Areo-kroil, gave it another blast and just came in from another failed attempt. I'm getting pretty worried. How 'bout another soaking and then heating with a large, electric soldering iron all around the ignorant threads. What are the odds of success?
    Blessings,
    Chiz
  • wardprobst
    • 681
    • Wichita Falls, TX, USA.
    • Craftsman 22811
    Chiz,
    I'd use a propane torch and heat it up pretty hot. If you can get to it to hammer on it with a punch that might help also.
    Good luck,
    DP
    www.wardprobst.com
    • ironhat
      • 2553
      Is it important to keep the heat isolated to the blade keeper bar as much as possible - off of the drum? Should I use the punch as close to the edge of the flat and in the direction that I want it to turn? And, last of all, would a knock with a flat bottom punch to 'shock' it, much like you would the end of the crankshaft for a recalcitrant blade retaining nut? Do I sound scared? You bet!!
      Blessings,
      Chiz
      • ironhat
        • 2553
        I was able to loosen the recalcitrant bolt by giving it a shot of Kroil and then rolling the roller into a position where gravity would would encourage it to follow the thread. I returned again in 12 hours and gave it another dose. Returning in an additional 12 hours it was easily loosened by benefit of the penetrating oil.
        Last edited by ironhat; 03-18-2011, 07:28 PM. Reason: Tried to make sense out of the syntax.
        Blessings,
        Chiz
          • 9247
          Sweet Deal...
          • wardprobst
            • 681
            • Craftsman 22811
            That's the spirit!
            DP
            www.wardprobst.com
            • toolguy1000
              • Mar 2009
              • 1142
              • westchester cnty, ny
              Originally posted by ironhat
              I was able to loosen the recalcitrant by giving it a shot of Kroil and then rolling the roller into a position where gravity would would encourage it to follow the thread. I retreated again in 12 hours. Returning in an additional 12 hours it was easily loosened by benefit of the penetrating oil.
              well done. sometimes, the best way to attack a problem is patience and thought. my mchanical engineer dad used to tell me, "if you're working hard, you're doing it wrong".
              • Long Shadow
                • Sep 2007
                • 25
                Hey Chiz, happy to hear that darn thing came out. I was about to suggest that you were a candidate for a "Screw Extractor Set" or then maybe drill and retap.
                Dan
