I recently bought the Nova Precision Midi Chuck for my HF 34706 lathe which was a Christmas present a few months ago. I've only had a chance to start using the lathe recently. While fiddling with the new chuck, I noticed the motor seemed awfully hot. So I did some experimenting.
Without the chuck on the lathe the motor (ambient temp of 79 degrees) the temperature reached 101 degrees after 5 minutes of no load. After 10 minutes the temperature was 110 degrees. And after 15 minutes, it had reached 123 degrees. With the chuck installed the temps were about the same.
Since there was no wood and no load, it seemed to me this might be a little hot.
What do you think? Is there something wrong or is this about right? Should I limit my turning to a certain number of minutes based on motor temp? What do you guys do? Thanks for any comments or advice.
