One Way Wolverine Sharpening Jig
    Is there a reason I couldn't make something like this out of the cutoffs I have in my shop? Or heck, aluminum that costs a lot less than 89 bucks?
    http://www.amazon.com/Oneway-2291-Wo.../dp/B000CSQONC
    Making them out of wood would be easy.
    • bthorne
      • Oct 2007
      • 82
      • Ruckersville, VA
      I've been thinking about making one of those myself. Here are some links to some homemade versions I've seen online:
      http://www.youtube.com/watch?v=BCVqWR1FcM0
      http://aroundthewoods.com/sharp.shtml
      http://lumberjocks.com/projects/16972
      An older post from here as well: http://www.bt3central.com/showthread.php?t=2453
      I had a link that had some more detailed plans for a vari-grind style accessory, but I can't find it at the moment. They're definitely out there, though.
      Bryan
      • BigguyZ
        • Jul 2006
        • 1818
        • Minneapolis, MN
        You can make anything out of wood, if you spend the time. Personally, the PSI kit was so cheap I just bought it and used that time I saved to actually turn.
          I made a similar jig. It was a relatively straightfoward project. It's the attachments that are tricky. Well, to be accurate, they seem tricky, but I haven't really tackled them in earnest yet.
            Regardless of the material, you want that horizontal component to be very stiff. Any flex will make it difficult to achieve a consistent grind.
            • Hoover
              • 1273
              • USA.
              King Heiple jig http://www.finewoodworking.com/pages/w00115.asp
              No good deed goes unpunished
                I actually dropped a jig project after the first test runs found the long bar flexed under use...
                The Wolverine jig is a great jig. And by now you guys know I won't spend a penny more than I have to just to get a brand name....
                For what it's worth, I hadn't known that PSI had pretty much the same thing for less money. If I had it to do over again, I would get the PSI...
                Of course if you are willing to do a little welding, steel stock is cheap enough....
                • BrazosJake
                  • 1148
                  • Benbrook, TX.
                  • Emerson-built Craftsman
                  Lotsa vids and plans on making your own.
                    I was thinking for the long bar I would use some t-track. It is pretty stiff and I don't think it will flex when I am sharpening something.
                      IF you manage to get stupid somehow, and get a catch between the stone and the tool, you will find out just how much force a grinder wheel can produce....
                      My initial attempt was with plywood laminations, and I was unhappy with the results. I think I would have been happy with the long arm / V rest being made with aluminum, square tubing...
