Nice circular saw innovation.
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    This saw has quite a few nice features on it.
    I don't know anything about Panasonic as a tool and don't want a metal cutter in a cordless type.
    Just noticed this one while researching.
    http://www.youtube.com/watch?v=DZHxm6DFdj8
    I like the height gauge on the guard. The blade brake and the battery minder. LED is a nice touch as is the dust or chip catcher.
    Right now for ferrous metals, I either use a Bosch jigsaw or a metal cutting bandsaw. Looks like one of these metal cutters would make it a lot faster to cut much of the stuff I need.
    Anyone have any experience yet with a metal cutting circular saw?
    that gives me the willy's the way he is holding a metal object (rod, tube, U-channel all demoed) in his left hand and cutting full depth and unsupported in free air holding the saw with his right hand. Is this recommended? Looks real dangerous to me.
    Would any of you do that?
      Not unless I was tired of having fingers...
      • Stytooner
        Roll Tide RIP Lee
        • 4301
        Yeah, but it's got blade stop technology.
        Once you saw through the first finger, you will release the trigger and only put a knick in the second one.
        No way am I condoning the video usage, just the tools design overall.
        • Tom Slick
          • 2913
          • Paso Robles, Calif, USA.
          • sears BT3 clone
          It doesn't look real dangerous to me. On a jobsite, wood is cut that way all the time and it is more likely to bind up than steel.
            I am going to have to check into the blade they used for metal. Abrasive blades use up quickly and get expensive.
            • Stytooner
              Roll Tide RIP Lee
              • 4301
              I did a little more research on these blades, Pappy.
              Everything points to expensive. Freud has some of these and the line is called Demon. Granted most reviews were likely from guys that used these on standard circular saws and they may have been turning a little faster than recommended.
              Here are the technical specs on a DIY version circular saw.
              http://www.evolutionpowertools.co.uk/us/fury_spec.html
              3500 RPM.
              Here is a link to a Milwaukee at Amazon.
              http://www.amazon.com/Milwaukee-6390...0470890&sr=8-1
              5800 RPM.
              I was also looking on that Evolution site and they stated that they get 30' of cuts through 1/8" mild steel per blade.
              I get likely 40' of cuts in the same from a $10 pack of Bosch jigsaw blades. Compared to $35 to $50 per circular saw blade, I'll just stick with what I am using.
              • unknown poster
                • 219
                When I was in welding school one of my fellow students bought an Evolution saw. I was an interesting concept, but not very efficient. Most metalwork doesn't lend itself to the circular saw the way carpentry does.
                For structural steel I prefer a horizontal bandsaw. They set up quick and basically operate themselves.
                For sheet goods I prefer a sheer. It is quick, straight, accurate, and easy. Compare the cost of an evolution blade to having a shop sheer your stock. Around here they are comperable.
                • phi1l
                  • Oct 2009
                  • 681
                  • Madison, WI
                  Actually, I have done that with lath sized pieces of wood on my little 12V 4" circular saw, but it is lighter & probably less powerful than this one, & I wasn't particular about the precision of the cut, either. It probably has a "special" metal blade that won't kick back....
                  • Tom Slick
                    • 2913
                    • sears BT3 clone
                    Those types of blades/saws are called "cold saw" because they don't generate heat while cutting.
                    http://en.wikipedia.org/wiki/Cold_saw
                    The blades are pretty expensive
                    http://www.mcmaster.com/#cold-saw-blades/=6j3z02
                    14" cold saws are common, here are a couple of blades.
                    http://www.amazon.com/MK-Morse-CSM14..._bxgy_hi_img_b
                    http://www.amazon.com/Milwaukee-48-4..._bxgy_hi_img_c
